Topics48,364
Posts813,343
Members9,215
Posts: 189 Likes: 1
Posts: 189 Likes: 1 |
No reply from Moderator - BUMP!
2018 S&S 110th Beetleback 1934 MX4 Beetleback 1965 Corvette Coupe 327/350
Posts: 1,649 |
The drop box link will not work for me, please help
Posts: 2,141 Likes: 43
Posts: 2,141 Likes: 43 |
The link still works. If you PM me your email address I will email you one. Your PM limit is over by the way, you need to thin some out.
Posts: 902 |
Hi, found this and thought it might be worth a look. fuel pump
Posts: 759 Likes: 23
Posts: 759 Likes: 23 |
Does seem a very good value, assuming the pump itself is of decent quality. I see from their website (highflowfuel.com) they have many different options, and also have the Mahle KL 167 filters available.
Steve Late 2012 M3W
Thanks for the info about the Quantum QFS342 fuel pump kit, it looks good value with all the kit parts and is an alternative if sourcing is a problem. The only down side I can see is that it draws quite a high current, 12.8 Amps against 9 Amps at 58 psi for the Walbro GSS342. From the Land Rover Discovery website (the original module is a Disco item), they found that many replacement performance pumps required heavier duty power supplies. The Walbro pump far exceeds the S&S requirement of 45 LPH, the QFS342 exceeds this by even more but draws more current.
Another updated Alternative Parts List. https://www.dropbox.com/s/889ymz55ygqjxhv/Updated%20list%2015%20%2018%20April%202020.pdf?dl=0. A couple of additions in the Fuel System section, rear gearbox rubber mount information and a Morgan supplied part number for the immobiliser link plug to remove the immobiliser from the loom. This number does not appear in the M3W parts manual and I have yet to get the correct part, so not 100% sure it is correct.
Posts: 360 Likes: 8
Posts: 360 Likes: 8 |
Continuing excellent job - thanks! Growing number of recommended suppliers is useful esp. for some of the "pattern" parts that are used and for which sourcing of reliable good quality parts is important (eg avoiding fake Walbro fuel pumps or odd size ball joints).
Latest version of the Alternative Parts List. https://www.dropbox.com/s/2rptn3wfh7mmu0x/Updated%20list%2016%2014%20July%202020.pdf?dl=0 A reminder that this is also always available on the MTWC website. https://www.mtwc.co.uk/news-post/ Additions are mainly to the front suspension ball joint information, thanks to all those who did the research and found out the hard way that not all GSJ268 ball joints are equal. Some additional information for making an immobiliser link plug, as Morgan no longer seem to make them. If you have any useful parts information you would like to pass on to other owners, please let me know and I will add it to the next update.
Posts: 697 Likes: 7
Posts: 697 Likes: 7 |
Is anyone aware of an alternative parts list for plus 4’s
