2 members (yobtaf, BHV), 305 guests, and 40 robots.
Topics49,860
Posts837,486
Jonny72
Page 5 of 8 1 2 3 4 5 6 7 8
SimonH Offline OP
Originally Posted by Hamwich
Very nice, Simon. It seems a shame that no-one will get to see it! What material is used for the bayonet fitting?
We use nylon 12 for the bayonet fitting
I prototyped on my hot rodded Ultimaker 2, but I sub these out now to a bureau and have them sintered...
It doesn’t matter if no one sees it, I know it’s been done right...
Simon @ Sifab.co.uk
Sifab temporary @gmail.com
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
SimonH Offline OP
We use lots of 3D printed components in nylon as end use products
These are the baffle flaps fitted around the collector boxes used inside the competition fuel tanks
You can see them here, surrounding an in-tank high pressure fuel pump
And here’s the pump and it’s 3D printed retaining bracket out side of the tank prior to fitting
Simon @ Sifab.co.uk
Sifab temporary @ gmail.com
Simon @ Sifab.co.uk
Very clever stuff Simon.
Originally Posted by SimonH
[Linked Image</div><div class=" class="post-image" style="height:auto!important;max-width:100%!important;"/>
And one showing the pump fitted
Simon @ SiFab.co.uk
Simon, it looks like the resistive strips for the fuel level sender are exposed to direct contact with the fuel ?
SimonH Offline OP
Simon @ SiFab.co.uk
Yup...exactly as the are in a Ford Mondeo, Focus, Fusion, CMax, Fiesta, et al
Simon @ Sifab.co.uk
Sifab temporary@gmail.com
Simon @ Sifab.co.uk
SimonH Offline OP
And for a change of scenery.....
Some BMW parts....
This is a 40 ltr "D Cell", designed to fit into the spare wheel well of a BMW 3 series, foam filled and with a small sump and pick up, to run an external fuel pump
These are Group A/DTM suspension strut top mounts, to suit the E30 saloons from the late 80's/early 90's. There's a huge resurgence on building these for Historic Touring Car Racing, so we were commissioned to manufacture a small batch run
Simon @ Sifab.co.uk
Simon @ Sifab.co.uk
SimonH Offline OP
Back to something nearer to Morgan...
This is the baffled sump I make for the Rover SD1 Group A historic Touring cars
There’s a few Morgan race cars using them too
The sumps are entirely fabricated from scratch, the flange is Nickel Bronze Tig welded on to minimise distortion
There’s also a bolt in Windage tray that fits over the top of the sump
Simon @ Sifab.co.uk
Simon @ Sifab.co.uk
Car component porn - thanks for posting.
Yours,
Addicted
Costock, UK
Disco 5
SimonH Offline OP
Had this little cutie in about this time last year for a fuel tank.
It's an Abarth 1000
The customer had an original works filler cap that he wanted to use, so we machined up a threaded collar to allow us to screw the cap onto the tank neck.
The cap also had to fit perfectly through the pre cut hole in the bonnet
Simon @ Sifab.co.uk
Simon @ Sifab.co.uk
What a tidy garage. It puts mine to shame. Maybe I’ll get the chance to use yours as an inspiration and tidy mine up during the isolation
