2 members (+8Rich, MOGDave),
218
Topics49,911
Posts838,149
Posts: 528 |
I have loads (30) of old (70s) golf clubs with steel shafts and steel/wooden heads.
I want to make something of them as a project while I am banged up in solitary.
Bearing in mind I have never welded anything in my life, can anyone recommend an easy to use not too expensive DIY welding kit that will enable me to weld connect/overlap stainless steel golf shafts as a possible garden ornament?
regards Ian
Posts: 1,309 Likes: 6
Posts: 1,309 Likes: 6 |
I would be tempted to silver solder rather than weld. If you weld onto thin metal as I presume the shafts are, they will blow through very easily.
Much cheaper and easier than welding I would say.
Bonesie Current stead -'The Captain' Black +4 'Life is like a garden, dig it' *Joe Dirt
Kit needed is pretty basic
Some flux coated silver solder rods Wire wool Plumbers type blow torch
Clean the two parts thoroughly. Apply heat evenly and as the metal starts to heat and turn red introduce the rod. The flux will melt and then the rod itself will too. Keep the parts heated evenly by waving the torch over and off the parts. If parts are clean solder will flow beautifully :-)
EDIT: if the shafts are chrome plated as I know some golf clubs are, I dont think silver solder or welding will work
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
regards Ian . It depends if you want to arc weld or gas.( Not have a chat... not allowed anyway).
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
Use J-B Weld Epoxy instead
Bob
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
Use J-B Weld Epoxy instead Good shout.
Posts: 9,554 Likes: 134
Posts: 9,554 Likes: 134 |
The club shafts are thin walled steel with a chrome (usually) plating. The thin walls make heat control difficult as they will overheat. Even brazing will be a challenge. Silver solder would be a better bet. The JB Weld or epoxy is a good idea and how about using decorative wire (copper, stainless) wrapped round as added strengthening and to disguise the joint? It could add some visual features. Some small holes drilled in the shafts would help JB Weld or epoxy “penetrate” for a better bond. As for bending the shafts, they are usually stepped not a straight taper and the thin walls mean they snap easily. A plumbers spring or a pipe bender are unlikely to work. I once had to have a snapped shaft replaced by our club pro. The club heads would either be cast or forged steel. If cast then they may be able to be snapped and that could be used as a feature too.
Posts: 528 |
Hi All Thanks for the responses As it looks as this isolation is for a while I have ordered one of these https://www.ebay.co.uk/itm/133137000695I am hoping that with this and some excellent youtube clips I will learn a new skill. Regards Ian
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Use J-B Weld Epoxy instead I would second this suggestion. Tough stuff.
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
Hi All Thanks for the responses As it looks as this isolation is for a while I have ordered one of these https://www.ebay.co.uk/itm/133137000695I am hoping that with this and some excellent youtube clips I will learn a new skill. Regards Ian I hate to disappoint you but that even on its lowest setting that welder will be far too fierce for thin wall steel tube. Arwyn
