8 members (B3MOG, TBM, Doug J, Dek, MJF, Guern, Ian Wegg, Bunny), 223 guests, and 81 robots.
+8Rich 76
Topics49,861
Posts837,531
Jonny72
Page 7 of 8 1 2 3 4 5 6 7 8
SimonH Offline OP
Originally Posted by Rog
Wow that looks stiff Simon. How did it compare to a regular trad ?
Regular trad has a torsional stiffness in the 100's of lbs/degree
The calculated stiffness of the Class A chassis was in the order of 4800lbs/degree
So stiffer than an Elise chassis, stiffer than an Aero Mk1 (which incidentally was the stiffest of the Aero variants), probably stiffer than a CX chassis too...
Simon @ Sifab.co.uk
sifabtemporary@gmail.com
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
SimonH Offline OP
This is a combined bolt in sump baffle and windage tray for the TR engined +4’s
As the drivers are pushing harder than ever these days, they are starting to see oil surge when cornering on track
The standard oil pick up on TR engine is a long sock like gauze, running along the bottom of the sump pan. It’s size makes it impossible to adequately battle the sump, so we designed a new pickup, that bolts directly to the bottom of the oil pump. We had to get these 5 axis machined because of some of the geometry of the part
The new pick up allows for a much smaller area to be baffled with one way trapdoors
An old aluminium sump was 3d scanned and then sectioned to check for proper clearance
Simon @ Sifab.co.uk
Sifabtemporary @ gmail.com
Simon @ Sifab.co.uk
SimonH Offline OP
To stop the quite frankly shocking images of the neoprene king and Kev getting it on that everyone’s got stuck in the heads....
Have a picture of an aluminium oil catch tank for a TR +4
There, isn’t that much nicer
Simon @ Sifab.co.uk
Sifabtemporary @gmail.com
Simon @ Sifab.co.uk
Much nicer. Thanks for the brain sanitiser.
Thanks Simon,
That is helping. I might be able to sleep tonight now.
Costock, UK
Disco 5
Simon
could you make an alloy catheter with aeroquipe type leads for those long journeys in my P4SS ?
SimonH Offline OP
Originally Posted by KEVFITZ
Simon
No problem, although welding the relevant adapter on to you might make you squeak a bit....
And in this instance you spelled P*SS wrong 🤣
Simon @ Sifab.co.uk
Simon @ Sifab.co.uk
SimonH Offline OP
We’re printing mask components for the NHS and other front line workers
In PETG material so they can be autoclaved or washed in boiling water after use
A local engineering consultancy is coordinating all the micro manufacturers
It’s like all the little boats going to Dunkirk!
Simon @ Sifab.co.uk
Sifabtemporary @ gmail.co.uk
Simon @ Sifab.co.uk
Nice one.
Well done Simon thumbs Mrs M may end up wearing one of those
