0 members (), 275 guests, and 48 robots.
+8Rich 95
John V6 52
Topics49,897
Posts838,017
Page 5 of 7 1 2 3 4 5 6 7
Originally Posted by Chris99
Originally Posted by RicHardy
41,000 miles on the original fuel pump and regulator and still going......
That's fate well and truly tempted innocent
I must confess to thinking the same thing! laugh2
Andy
Originally Posted by britmog
My pump just died, no pre-warning signs just went straight to its maker. I said to myself no its not dead its just sleeping, banged it about a bit and said that's not sleeping. You know its dead because there is no pressurizing sound on start up, then of course you check the cutoff switch and if still no pressurizing sound - your dead sir.
What pump are you going to replace it with? And from where Bruce?
I replaced the pump with a Walbro GSS342 from Amazon like this one:
https://www.amazon.com/dp/B000WCY80E/ref=psdc_15728151_t1_B000EVN7W8
I searched around to try and ensure it was a genuine Walbro pump. This link is helpful in explaining what is genuine and what is a knock off:
https://aftermarket.tiautomotive.com/about/
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
This is also useful to help spot a fake Walbro fuel pump. https://www.driven2automotive.com/blog/spot-fake-walbro-gss342-fuel-pumps-2017-18/. There are a lot about it seems. It's a good idea to buy from a reputable source. The plastic internals of the fake are a certain identifier.
Thanks Britmog which hose did you buy for in the tank?
2017 M3W Sport Green
I used the existing hose by gently heating it with a hairdryer to remove it from the connectors and then fitting to new pump with clamps. I have since ordered the convoluted hose as back up if I need to replace the pump again from Ebay.UK:
https://www.ebay.com/itm/1x-In-Tank-Conveluted-Fuel-Injection-Hose-Plastic-210mm-PFH0825/232610482596?hash=item3628aa49a4:g:TAAAAOSwLdBaQ4A5
Bruce
2013 M3W (Olga)
Thanks. With those measurements I ended up finding something pretty close from Walbro. It is near impossible to find hose measurements for all the hoses Walbro has but this one looks pretty close.
https://www.amazon.com/gp/product/B00FMV3AC2/ref=ox_sc_saved_title_1?smid=A3TW1WCPSO49LP&psc=1
Walbro TF0001275 Fuel Pump Replacement Hose
For the 1/4" spade connectors I found these
https://www.amazon.com/gp/product/B0071NC5NO/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Supco T1111 Quick Disconnect, High Temperature, 16-14 Gauge, 1/4" Female Tab (Pack of 20)
I guess I will quit carrying around the fuel pump in my tool bag and put it to use. For the price of the Walbro you would think the factory would switch. Clearly this is a pretty hefty and quality feeling unit. From one I have read online Walbro has great reliability.
Please Post on how the install goes and if there were any issues that were unforeseen.
Curious does return line go through the filter and the feed line go directly to the injectors?
That's correct. The filter is on the return side and provides the calibrated restriction that yields the correct fuel pressure.
Late 2012 M3W
Is that normal? I would have thought the filter would be between the pump and injectors. I guess it removes the need for a regulator. I think I will consider putting an inline filter before the injectors as well.
