6 members (RichardV6, TBM, SailingTom2, Paul F, Mick Annick, Alan Patterson), 222 guests, and 27 robots.
+8Rich 99
John V6 57
Topics49,908
Posts838,123
Page 4 of 5 1 2 3 4 5
TBM #627707 02/04/20 02:58 PM
Originally Posted by TBM
I am getting serious garage envy. I have a chunk of muliti layered manky concrete (thanks toprevious owner) out the front of my house to work/park on.
Am considering getting it dug out and relaid/levelled properly at some point.
If getting new hardstanding think of resin bonded/bound - not sure which - but very strong/resilient and porous - in all the floods recently we did not have a single puddle wherea before we would have had several inches of standing water. Good grip in winter. Not cheap but I would get it again.
B3MOG #627718 02/04/20 03:25 PM
TBM Online Content
I like the resin, but I've read that it can react to oil/petrol/ brake fluid. I've eaten away several chunks of tarmac for the same reason.
Concrete/gravel is a lot more resistant.
Fuel.inj #627741 02/04/20 04:39 PM
Originally Posted by Fuel.inj
I’ve always understood that proper Land Rovers leak oil and leave their calling card. I’ve had my Defender for a number for years now and hardly a drip. It worried me initially to a point that I checked and changed all the oils ie engine transmission axles etc and it’s still oil tight. It must have been a mid week build!
Wrong thinking. Its a Friday car - they knocked off early and forgot to install the leak.
TBM #627782 02/04/20 07:32 PM
Would not be keen on gravel in this situation - some people along the road have it - both gravel in two houses and slate chips in another - it is a blessed nuisance as it spreads all over the pavement and makes walking past or running past a nightmare - nearly sprained an ankle on it today when a stone shifted when I trod on it. Concrete also is not allowed in some areas now as it does not let the water soak away.
The resin is resistant to most substances and is easily patched if a major problem. I`ve found oil etc. washes off quite easily with a bit of detergent & water.
B3MOG #627792 02/04/20 08:28 PM
Originally Posted by B3MOG
Due to the lockdown my garage build is on holds I am trying to plan the fit out, any suggestions will be welcome.
What is the best material to insulate the roof and walls?
What is recommended for sealing the floor, I will then cover it with carpet tiles. (the builders suggested covering the floor with a upv sealer/adhesive)?
Any suggestions most welcome , I feel as though I am in limbo at the moment my car is miles away in storage till the garage is built.
David Byrne
David, that's a great project.
I have an insulated concrete floor with carpet tiles but the concrete isn't sealed.
I believe that if you have hardbacked/bare tiles it is important to have it sealed.
I have cushion backed tiles which allows the moisture to dissipate and are very soft underfoot/tyre but aren't cheap (I got mate's rates).
The manufacturer laid them for me and recommended that way. However, he did say that if I was using any other bare (without any underlay etc) tile it is better to seal it to avoid moisture being trapped between the concrete and the tile.
I know that's probably stating the obvious!
I also had an Alutech sectional insulated door fitted and it's spot on plus reasonably priced.
www.alutech-group.com/en
Rich Maroon and Ivory (ish) Plus 4 2015
B3MOG #627796 02/04/20 08:56 PM
David,
I don't know whether this has been posted on here before but you might find this website interesting.
www.garagejournal.com/forum
TBM #627809 03/04/20 04:21 AM
I did suggest removing the bay window and just putting a flat front on (to give me a bit more room) but that did not go down well smile
Not much chance of persuading them to remove the bay, put in doors, and turning the front room into a workshop then?
Hamwich #627810 03/04/20 05:43 AM
TBM Online Content
Nope, she's being very stubborn. We have a dining room at the back of the house with french windows out on the patio. She won't even entertain the possibility of me sticking a bike in there. No sense of compromise.
TBM #627814 03/04/20 06:03 AM
grin2
I wan't allowed to bring the Harley in during winter either, it had to stay in the garage...
B3MOG #627823 03/04/20 07:03 AM
I had a Guzzi Le Mans that was in storage whilst we were in Kenya. We moved back to Holland to another house & I serviced it ready for the road in the kitchen. The boss was still in England at the time.
