1 members (Saxonian), 266 guests, and 69 robots.
+8Rich 81
Topics49,849
Posts837,424
Page 9 of 26 1 2 7 8 9 10 11 25 26
SFG #628081 04/04/20 08:20 AM
SFG Offline OP
Thanks for that. So if the other switch is failing , it is intermittently making a contact, but not otherwise. Seems less likely to me.
SFG
2012 4/4 Sport
Originally Posted by +8Rich
Originally Posted by SFG
So I deduce from the above that BOTH switches must have failed, since I can’t replicate the function of the fuel cut out switch. Perhaps it is making intermittent contact . Can’t think why it would be corrected by blipping the throttle though.
Does anyone know if the switch is “open circuit” normally, and “closed circuit” when braking, or the other way round? If the former, maybe I should just disconnect it? ( after footling about with the new brake light switch terminals, they are too well protected to get a tester on them, without getting the guard plate off and exposing the neoprene nightmare again.)
P.s where can I get one of those gadgets that makes a V8 noise, please?
Normally open as you guessed.
Here goes --
Now that is clever.
SFG #628093 04/04/20 08:57 AM
SFG Offline OP
Could anyone confirm how the pedal cut off switch should work. Does shut the engine off if you press the brake? Mine doesn’t.
Does the car have to be moving, in gear, or otherwise?
SFG
2012 4/4 Sport
SFG #628099 04/04/20 09:48 AM
E
E
Hi SFG,
I can't help, I only know the brake cut off the fuel because I dry the brakes off after washing the car, I drive gently with the brake lightly on while on a light throttle just to warm the discs and pads so the water evaporates and doesn't mark the discs or pads whilst in the garage,
Hope you sort it soon
2017 Mercedes Benz SLC 200 AMG.
2019 Mercedes Benz GLA 200 AMG
Now Ex-Mogger!
SFG #628125 04/04/20 11:09 AM
Stuart I wish I could as I sense your frustration at this fault, it does seem likely that both switches were suspect to me and intermittent with first the brake light problem and later the hesitation issue.
I also wish I still had my 4/4 Sport so I could carry out some back to back checks for you but I don't however logic tells me that the ECU would have to have enough information to know that it was travelling i.e. engine under load before it attempted to cut the fuel to a tick over speed. Now I haven't read that anywhere but to me it's logical.
There are others with far more knowledge of these models that have written books on them that will hopefully summon the courage to step forward and help you as well.
If you were closer I'd love to help you with this one.
Good luck with it.
SFG #628126 04/04/20 11:10 AM
I might have this wrong but in normal use you'd be on the gas then off the gas an onto the brake with right foot and this would cut the gas off.
If you revved the car with your right foot and braked with the left foot this isnt what you'd normally be doing in practice as you're still on the gas and using both feet.
Rob
SFG Offline OP
Good points above. I was going to rush out and check , revving up and the moving my foot on to the brake.
But that would be the same as just taking my foot off the accelerator , the engine would slow down to tick over 🤔
If the system is working properly on my car, and if the fuel cut off is there as a last resort for when the accelerator is stuck open, I can tell you that it doesn’t do this!
Still mystified
Originally Posted by exbiker
Hi SFG,
Hi exbiker - do you mean the engine cuts to tickover When you are applying light throttle and braking at the same time
? So the brake over-rides the throttle?
SFG
2012 4/4 Sport
SFG #628156 04/04/20 01:59 PM
Stuart
This is from the 350z forum. Its possible the switch may reduce the revs rather be an on/off switch which could tie in with your hesitancy problem
Quote
I seem to recall Raceboy saying that he still had throttle while doing heavy braking heel-toes, but only like 1/3 as much as he should. So he could still blip on a heel-toe, but it was like being in slow motion. I've noticed this too. My blips rise faster if I'm not braking heavily (or not braking at all).
Rob
SFG #628170 04/04/20 03:22 PM
My 2011 4/4 has two switches. But I had the accelerator pedal modified so I can heel & toe. The engine blips fine so I guess the 2nd switch is just a back up brake switch.
SFG #628179 04/04/20 04:07 PM
SFG Offline OP
Ice pack: i hoped that, but then my brake lights failed. Also a second switch is not shown on the wiring diagram. ( but then neither is a fuel cutout switch!)
SFG
2012 4/4 Sport
