7 members (Doug J, Dek, MJF, TBM, Guern, Ian Wegg, Bunny), 210 guests, and 79 robots.
+8Rich 76
Topics49,861
Posts837,531
Jonny72
#628199 04/04/20 06:23 PM
clutch pedal falls flat to floor.
before i get under .is the return spring on the Moss bos slide mechanisium to weak
or ts there a spring or retaining clip on the pedal itself.
The diaphragm spring on the clutch cover is probably responsible for 95% of the effort in returning the clutch pedal. The spring on the slide mechanism is only a helper spring
I'd advise getting under and having a look to see if it's anything obvious such as a sheared clevis pin.
Arwyn
clutch works fine just a case of reach down to the floor to lift before i can get foot on pedal
embarrising in traffic
clutch pedal returns ok from engagingthe clutch the pedal then floops back towards me onto the floor
