7 members (John V6, How, DCH, MartinB60, IcePack, Luddite, TBM),
362
42
Posts837,279
Posts: 45 |
Hi everyone.
I need some advice. Today I started the car first time this year. Everything seems to be fine except that the direction indicators are not working. If I press the hazard switch, nothing happens. The car in question is a 1998 +8
Could this indicate that something is wrong with a relay? Where should I start to look?
I have been looking around a bit behind the dashboard during the winter, so there is a chance I have caused the problem myself.
Best regards
Greetings from Sweden. Morgan Plus Four Club Sport 2023
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
Start with the hazard warning light relay. Wiggle the connections...……….
Posts: 45 |
Start with the hazard warning light relay. Wiggle the connections...………. Thank you for the tip. For me who is not a car electrics expert. Does this relay look just like a standard relay?
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
Yes & it will be in that mess of wires behind the dash. Put your handle under your drivers side near the tunnel. It should be in there.
Posts: 1,309 Likes: 5
Posts: 1,309 Likes: 5 |
Do you also have a fuse board under the hood ? I had my indicators stop working and it was one of the fuses in there that just needed re-seating.
Bonesie Current stead -'The Captain' Black +4 'Life is like a garden, dig it' *Joe Dirt
The fuses are under the dash above the tunnel
Posts: 45 |
To report on progress, and more questions.
I have not yet found the problem. I found three relays behind the dash. All worked OK. I have a wiring diagram that seems to be fairly accurate. According to that I should have 12V on a purple/red wire at the hazard switch. That is OK. I have tried to mannually short the wires at the indicator stalk. No change. I can not find any faulty fuse. Yet.
Questions. According to the wiring diagram there should be something called a "Flasher unit". How does such a thing look like? Since the hazard switch has 12V, but I dont hear any relay click, I start to wonder if the problem could be in the earthing side of the realys. What do you think about that idea?
Best regards
Posts: 2,116 Likes: 68
Posts: 2,116 Likes: 68 |
Hej Björn! A flascher unit is also kind of relay! So it looks like a relay.
It looks like a relay. The earth is on the rhs front wing behind the tyre
Posts: 45 |
Just wanted to tell everyone that the problem is fixed now. After investigating all the relays I could find and double-checking all the fuses, nothing was found to be wrong. I then started to look for loose calbles, but after a while I had to admit defeat. I do not have the knowledge or the place to be to really start pulling everything behind the dash apart.
So I enlisted the help from a proffessional. He could fairly quickly find a loose cable somwhere. I do not know exactly where. So now everything is good again. Well, except for me feeling stupid. But I can take that.
