0 members (), 200 guests, and 41 robots.
+8Rich 101
John V6 57
Topics49,911
Posts838,152
Georgetoad, woolfie
Could I draw upon your collective wisdom and ask you if would it be possible to attach the Ctek with its tiny ring terminals permanently and safely to the starter battery without cutting the original cable and installing a new terminal. I've seen something called a "KnuKonceptz" terminal which would be ideal but not available in the UK.
I've thought of soldering the Ctek connector directly to large washer but that seems to be somewhat naff.
2015 Plus 4 (GDI) Sport Green
On all my Moggies I have attached the Ctek cables to the tightening nuts of the battery terminal clamps using the Ctek ring terminals, then ran the cable under the shelf and around edge of carpet so it can be easily connected to the charger. I suppose it depends on what battery terminals you have but changing the ring connectors would not be difficult at all.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Put an in line fuse in the positive wire, close to the battery, just in case.
The Ctek unit itself has a cut off for overload, etc.
Bruce
2013 M3W (Olga)
I have done exactly as Bruce because I want to keep the Odyssey AGM battery always fairly topped up, the AGM battery requires about 30% of its a/h rating from the charger in the bulk phase so as not to reduce capacity over time .
If the car has not been out I put on charge every three weeks, and Dave my Ctek cable has that fuse in it.
99 plus 8 indigo
I just plug mine into the cigarette lighter socket, saves all this extra work and works a treat!
Tony
1994 Connaught Green Plus 4
Mine has lived on the charger via the cigarette lighter since new with no problems
Far better to use the supplied ring terminal option direct to battery. Less resistance so charger gets the opportunity to charge within its full voltage control regime. The extra terminal lead option on my Ctek clone is fused within, has non reversible connector and cover for when not in use, when its tooked under carpet.
I have done the same the battery is now 7 years old and keeps full charge
Very much in the dog house, could be up for rehoming
Can't remember which model my Ctec is but it came with 2 sets of cables, 1 with crocodile clips for direct to battery connection and 1 with a cigarette lighter plug.
Why not call Ctek and ask them for a solution.
As it happens I always use the cigarette lighter plug on Mog with no problems but I will use the crocodile clips to condition our Freelander's battery before we fire it up again.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
