Topics49,868
Posts837,640
Posts: 3 |
Is it possible to remove the radiator on a 1997 +8, from underneath. I don't want to remove the cowl if I can avoid it..
Posts: 1,464 Likes: 99
Posts: 1,464 Likes: 99 |
I did just that on my plus 8.
Fairly straightforward but I decided to remove the rack and adjust it at the same time which made it much easier. Surprisingly the rack is very easy to remove.
Jack the front as high as possible
Posts: 932 Likes: 11
Posts: 932 Likes: 11 |
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
When removed take the opportunity to use the space cleared to clean, check as much as you can. A good time to flush the engine too.
