0 members (), 305 guests, and 72 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
#634590 02/05/20 09:07 PM
PaulyG Offline OP
Uh oh. Got out today for a run. Picked up some food, and when I came out there was something wrong with the shift.
To change gears I have push down, or the shift just kind of flops around. I am assuming a pin of some sort has sheared off. The big question is how do I get to it? Do I have to remove the seats and remove the transmission tunnel?
73 4/4 "Henry A"
53 +4 Flat Rad "Pug"
84 Citoen 2CV Spec "BeBe"
60 MGA
https://morgan34.org/
PaulyG Offline OP
73 4/4
73 4/4 "Henry A"
60 MGA
Hard to say without removing the leather/pvc g gearbox cover but the best case scenario is that the gear stick has become unscrewed from the box. Can be replaced without having to remove the actual metal cover but a bit fiddly to do.
Worst case scenario is that the plastic washers in the gear lever have split. In this case the lever must be replaced as I don't think a repair kit is available
Not sure where you would get a OE replacement from, the FoMoCo part no for a 4speed gear lever I have is listed as NLA.
There is an upgrade you can do with a rose jointed gearshift which does away with the plastic washers. I had one from Matt Lewis Racing for my 4/4 (before I went 5 speed), it needed some fairly radical shortening. Worked pretty well but was very easy to engage reverse when you wanted 1st!
Arwyn
I can't speak specifically for a 73 4/4 but there could be a grub screw at the bottom of the shaft which has come loose or fallen out. Remove the gearbox cover and look down at the bottom of the shaft.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
PaulyG Offline OP
Thanks all. To pull the cover/tunnel from around the gear box, do I need to remove the seats?
73 4/4 "Henry A"
60 MGA
Normally the answer is yes. Not a difficult job , but it does take a while , and it is a tremendous help to have someone on top while you work underneath. Be prepared that some of the nuts underneath will be seized , so be ready with a hacksaw or a Dremel to cut them loose.
You also need quite bit of space around the car to put the items down as you extract them.
Andy G
1999 +8 , Indigo Blue.
GoMog has a parts list & diagram here
https://www.gomog.com/allmorgan/gearbox44Ford.jpg
PaulyG Offline OP
I pulled the covering off the tunnel and I can get into the top where the shifter goes. Shifter forks look fine, as does the spot on the shaft that it sits on. I pulled out a piece of something that looks like plastic, possibly 7x381 from the diagram. The diagram shows a couple of other parts that aren't numbered. I don't know what those are.
I assume that plastic piece is what holds it together. Anyone know where I should go from here?
73 4/4 "Henry A"
60 MGA
Could you possibly post some photos?
1972 4/4 2 Seater
PaulyG Offline OP
I tried. I need to try again.
It seems that something came off the shift and it fell apart. I'm going to try and find a replacement in the US
73 4/4 "Henry A"
60 MGA
