Topics49,909
Posts838,127
Posts: 463 |
I'm thinking of changing my headlights to a pair of Lucas LUB384 with Pilot. Planning on using the pilot for DRL. Is anyone running with this or the LUB314. Both units are H4 with P43t Halogen bulbs. Greatly appreciate your feedback.
Dave 98 +8 Corsa Red 74 MGB Red
Posts: 6,676 Likes: 441
Posts: 6,676 Likes: 441 |
I'm thinking of changing my headlights to a pair of Lucas LUB384 with Pilot. Planning on using the pilot for DRL. Is anyone running with this or the LUB314. Both units are H4 with P43t Halogen bulbs. Greatly appreciate your feedback. I've done this in my 72 4/4 - not for DRL (I'm not a fan) but as an extra pair of sidelights. Have LED's in both sets. Fairly easy - I needed to need to trim the metal headlight bowl backplate as it fouled on the sidelight bulb holder. I just cut a narrow U shape using a drill and a dremel. Tried to get the additional wiring through the same hole as the main headlight but it was too tight, so drilled another hole below and stuck a grommet in. I spliced mine into the wing sidelight circuits, but of you want DRL you can wire them up to an ignition live.
Posts: 27,846 Likes: 764
Posts: 27,846 Likes: 764 |
I fitted the plastic ones with half moon LEDs as shown in miscellany. They are from a Land Rover. £50 on ebay from memory ![[Linked Image]](https://www.tm-img.com/images/2018/04/14/DSCF2179.jpg)
Posts: 4,612 Likes: 15
Posts: 4,612 Likes: 15 |
I did the same as John years ago. Buy them of the web for £60 or so a pair. Hold the usual H4 bulbs. I fitted the plastic ones with half moon LEDs as shown in miscellany. They are from a Land Rover.
Posts: 1,149 Likes: 19
Posts: 1,149 Likes: 19 |
The look great so did u ditch the original lights or bin them?
Morgans 1934 MX, 1947 Series 1, 1956 +4 TR4, 2000 +4 T16 Triumph Herald 1969 13/60 Morris 1970
Posts: 28,911 Likes: 354
Posts: 28,911 Likes: 354 |
If you're referring to Steve, he gave them to me. Spares for my 90. I've used one. Cheers, Steve!
I have 4 OEM units in stock as someone else gave me a spare set. If I do a mod I generally like to keep the old bits in case I sell the car & the next guy wants originality.
Posts: 5,471 Likes: 476
Posts: 5,471 Likes: 476 |
John, I had a garage full of stuff stored on the basis of you keeping spare headlights.... Only in recent years have I cleared out..though still have a few treasures… Lotus hub cap as an example, and loads of tools I am unlikely to make much use of in future...hmm.
Yes but mine are now organised by type on shelves. If this goes on I might start to label the boxes etc & put it all on a spreadsheet. Today I mopped the garage floor.  anyway I find if I get rid of something the next month I need one of them.
anyway I find if I get rid of something the next month I need one of them. That is ever the way after a clear out and that which had been my excuse for too many years John..
