Topics49,870
Posts837,673
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
Having just made a lifting bracket (in anticipation of a Bleazey job on the Centa) and recognising that the threadings for this are the top mount for bike installation leads one to wonder (as Andy did above) that if a brace could be conceived it could damp the engine's movement very effectively - there is a lot of mass flopping around quite a long way above the soft rubber mounts so the amplitude and force of the vibration is no surprise.... A few years ago, when I was visiting the M3W assembly area at the factory, I saw a large box of metal brackets and asked what they were. I was told they were the engine lifting brackets that every S&S X-Wedge came fitted with from S&S and that these were going for scrap. I was given one and it has been used a few times now. I wish I had grabbed a few more. Do you think one could be purchased either from MMC or S&S ? You don't need anything as fancy as the S&S bracket a bit of bent angle works fine. ![[Linked Image]](https://www.tm-img.com/images/2020/05/04/IMG_2923.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/05/04/IMG_2903.jpg)
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Rob, thanks for the photo of your lifting bracket.
Posts: 488 |
Rog, what was the reason for removing the engine? Please don’t take offence but your workshop gives mine a run in the untidy stakes🤣
Rog, what was the reason for removing the engine? Please don’t take offence but your workshop gives mine a run in the untidy stakes🤣 I had the engine out to do the Bleazey mods to the Centa, just as precaution as I do a few long trips and wanted to check it out having done over 20,000 miles on the inserts which were in there, as it turned out they were fine. Yes I agree with the untidy comment you probably won't believe if I said prior to the lockdown I made three trips to the tip to get rid of junk. Still a few more to go I guess.
Posts: 488 |
Junk? There’s some useful stuff there, be careful what you get rid of, you never know when you may need it, that’s my philosophy anyway!
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
I am sure that pedestrians are going to just come on over and touch those sharp fins
Posts: 399 Likes: 15
Posts: 399 Likes: 15 |
As Rog says, the bracket is easy to make...a bit of steel from the scap box (or a comer of the garage) plus some hi-tech CAD (cardboard aided design)...
Posts: 786 Likes: 18
Posts: 786 Likes: 18 |
That is great, several different lifting brackets all designed by CAD (love the previous acronym).
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
GLLOQ,
How did you unbolt the engine (4 studs) from the 'bellhousing' that surrounds the Centa unit? Has there been a previous modification that allows this?
Steve Late 2012 M3W
