0 members (),
290
90
Topics49,870
Posts837,668
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Here is a bit more of the system running. It drives great and has much better throttle response. https://youtu.be/73vd4aplZGA[video:youtube] https://youtu.be/73vd4aplZGA[/video]
One of the benefits of the new fuel system is that the pesky Check Engine Lamp is no longer on. It has been on for about a year since a double click at the gas pumps and now it is GONE!!!!
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
Did you check your fuel pressure before installing the new system? Or check fault comes with Protune? I'm guessing you were running low fuel pressure, and the new system with verifiable and adjustable pressure regulator both improved running and eliminated the fault.
Steve Late 2012 M3W
Never checked the pressure before changing the system and it ran fine, except for the lamp that came on after a double click at the gas station.
I do know the throttle response is better now.
No, I plugged in the ProTune but need the ProTune for Dummies to study to figure out how to use ProTune. I don’t even know where that fault is detected.
