I think SFG has maybe given you the answer for a 4 wheel Morgan, you shouldn't have to hacksaw a 2016 M3W exhaust. The M3W the exhaust bobbins are not too tricky to replace and are accessible. You can usually align the exhaust better if you loosen the two header stud nuts to allow the headers to move slightly, tighten them up again once it is all in place and not stressing the mountings. You can also elongate the mounting holes to get better alignment. Replacement bobbins are very similar to Renault 25 items but a look on eBay will usually find something suitable at a fraction of the cost. They are M8 studs and about 25mm tall. I don't think a 2016 installation exhaust will have the early type mounts, it was the early ones that gave problems and sometimes allowed the pipes to hit the ground.
Yes, sorry, it’s so unlikely that I would have anything technical to contribute that I got too excited!
