Morgan Aero 8
1 members (JMcL), 132 guests, and 61 robots.
+8Rich 94
Posts837,276
Page 4 of 6 1 2 3 4 5 6
Originally Posted by James B W
wrapping the complicated curves of the console would be tricky and probably best left to a pro.;I'm still not convinced it would look 'right' when/if completed .....
I investigated hydrographic dipping a while back as I think this would solve some of the issues with curves, etc.-
https://en.wikipedia.org/wiki/Water_transfer_printing
Sadly, at the time, an 'engine turned' pattern was not available.
Kevin, having re-ignited my interest in this,I have found this guy in the States who does custom graphics for dipping -
https://www.fractalcamo.com/store/p201/Turned_Silver_Leaf_Pattern.html
You would still need to either buy a dipping kit or (probably more realistic) supply the custom film to a local dip specialist.
As the console gets a lot of wear/abuse, the 'dip' could then be 2K lacquered to give it a bit more resilience
Still a lot cheaper than a new console (if they were even available confused2 )
James
Funnily enough I was just about to recommend hydrographic dipping, took the words out of my mouth! thumbs
Personally thought I would still have it returned by an aluminium specialist, there will be someone who can do it.. and keeps it original then.
Aero 8 GTN #11
Originally Posted by KevinMcR
Forget that I see they do provide custom services so have contacted them and will let you know when I hear back from them.
- yes, I spotted it first because he can/will match any design.I then noticed he had an engine turned pattern already available.....
If the cost is not exorbitant,I would be inclined to get him to match the dash panel exactly (or as near as the process allows).
I have several versions of engine turned 'wrap' (one bought from the States at great expense!) and none of them look 'right' swear
Let me know how you get on with your query and I'll probably chip in for some of the film too - help split the costs.... thumbs
James
RR Evoque P300E Autobiography
Smart Brabus Convertible
Monkey Z125
Can anyone tell me if their S1 rubber door seals have a small gap mid centre bottom under the door drainage hole? New seals working very well but noticed after washing lots more water when opening door so it must be getting trapped.
When we produced polished or matt finish stainless steel sheet for pressworking we used to apply a plastic film to the surface. Cant remember what it was called - too many years ago, but the point is that you can form metal with fancy surfaces and not destroy them by plastic coating.before forming and removing the film afterwards.
Hello Howard. I think the issue with the forming of the console is that the press isn't available to form the console and the price would be high to produce one with possibly very little return so even if we could form it from flat turned panels using the method you described what would the cost be and would anyone take on the initial expense?
Cain did explain to me the reason for the cost was that producing the turned metal was time consuming skilled work but I was still gobsmacked by the price at nearly a thousand pounds if one were available. Also if I did bite the bullet and spend the cash and as James has said the console takes a lot of abuse and ends up in a scruffy scratched state very quickly with no chance of polishing defects out without destroying the turned finish.
A grand? Seriously?
I’m happy to do one offs at dramatically less than that
Simon@sifab.co.uk
Sifabtemporary @gmail.com
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Price I was quoted was 795 plus VAT Simon. Is a replacement with same form possible then?
I’m on daddy duties today but I’m back in the workshop tomorrow, give me a buzz to discuss...
Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Cheers Simon. Will call tomorrow.
Have had chat with Simon and if I send him my console he is willing to use it to make a mould and form a new turned console for me. He has said it will be around the £300 mark and we can cover it with ppf for more durability.
James if you are interested he is happy to make 2 from my mould as is as easy as 1. He is busy getting everything in shape at the moment so I've to call him in a couple of weeks to agree a date to send the console to him.
My car doesn't have the tpms any more so he can convert the hole to a trinket tray or something else more useful at the same time so big result I think.
