0 members (),
315
43
Topics49,897
Posts838,017
Posts: 128 |
I will be fitting my new SiFab Aluminium radiator soon, clearly draining the coolant prior to removing the old radiator!!. Is there a recommended brand of anti freeze/coolant mix? My current mix, as it was supplied from the dealer has an orange colour look to it. Thanks, John ----------------------------- 2011 Plus 4 (Marty)
Posts: 1,415 |
Don't change from the current longlife coolant, if you mix different types (OAT, Glycol, etc) then can react with each other and crystallize, or gel inside the engine and radiator
Simon@Sifab.co.uk sifabtemporary@gmail.com
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 2,095 Likes: 75
Posts: 2,095 Likes: 75 |
Motorcraft Superplus to spec WSS-M97B44-D in a 50% concentration.
Posts: 1,149 Likes: 19
Posts: 1,149 Likes: 19 |
when did you last look at your water pump, it may be worth changing at same time.... DSC_0044_4 by Robert & Ali Davies, on Flickr
Morgans 1934 MX, 1947 Series 1, 1956 +4 TR4, 2000 +4 T16 Triumph Herald 1969 13/60 Morris 1970
The OAT organic red coolant life expectancy 5 years and the older blue coolant Glycol 2 yearsas Simon of sifab says above. I have fitted SiFab radiator to my TR4 1958 Morgan and I am very pleased.
The OAT organic red coolant life expectancy 5 years and the older blue coolant Glycol 2 yearsas Simon of sifab says above. I have fitted SiFab radiator to my TR4 1958 Morgan and I am very pleased. Just to avoid confusion, neither of these colours is appropriate for the 2011 +4.and as John said, his is an orangey colour (just like mine) My earlier post quotes the spec in handbook which is the same as the Motorcraft superplus spec.
Posts: 625 |
And watch out if you are using silicone hoses that are not certified for use with OAT coolant - it eats away at them. But as yes as others have said Never mix the orange/red OAT with the non OAT coolants.
Cheers John 2011 4/4 - "Elrond" 2007 Elfin C3 Clubman - “Gimli”
Posts: 9,552 Likes: 134
Posts: 9,552 Likes: 134 |
The colour is not a good guide! There is no colour standard for the different types. Manufacturers are not all the same. You need to check the actual specification for coolant type for your system and use the same. The water pump check is worthwhile too. Also a good flush of the engine cooling system.
Posts: 730 Likes: 58
Posts: 730 Likes: 58 |
I've stripped down my Crossflow, removed the head, replaced the water pump. I'm also repacing the Rad with SiFab rad, which i brought last May/June. What is a good coolant? In the pass I have used a waterless coolant from Caterpillar.
Navy Dave 1976 Morgan 4/4
Posts: 6,675 Likes: 441
Posts: 6,675 Likes: 441 |
Personally I use water and a traditional Blue/Green antifreeze on a 50:50 mix.
I'm sure I read that there may be an issue with OAT technology and some classic silicon/copper parts which steered me away from using it.
