8 members (M3WMW, JMcL, John Winn, TBM, Black Adder, Strathaven, bmgermany, RichardV6), 226 guests, and 32 robots.
+8Rich 99
John V6 57
Topics49,908
Posts838,124
Page 2 of 5 1 2 3 4 5
I have never jacked the car up to grease the kingpins and I would probably be considered a bit slack about greasing. I grease the kingpins before and after every long trip. In some cases that trip could be 5 or 6,000 km. If it is convenient I will get some grease in before heading for home but usually it would be a hassle to find a garage to do it. I don't carry the small portable grease gun because I worry about it leaking if gets hot.
The factory kingpins were replaced with hard chrome pins at about 13,500 km when I had the Suplex (now SSL) front suspension kit fitted. That was over 50,000 km ago.
I now have the hard chrome kingpins - Thanks Colin they are still doing fine!- I grease lower nipples until old grease comes out then clean it off then do the upper ones until grease starts to emerge from the bearings again. Clean off - job done. Also don`t use the remote as it is a good idea to see the grease start to emerge and also to have a quick visual check down under - if you will pardon the expression!
Don't know if you remember this Phil, I had 5 cars booked in that month ;-) Peter Mulberry supplied all the stock, all Hardchromes with Spiral Grooved P/B Bushes..... superb quality.
BR Colin
Posting Desperado
Posting Desperado
Tim you have been copying me . I get the mog out for spring but the only pig is that nipple behind the gearbox you can bet what you want but no matter how you push it its always pointing the other way . Going to have a word with a local garage along the road to see if he will let me hire one of his his ramps so I can paint the chassis from underneath I can paint the chassis under the bonnet with special brushes I have. One wanted 160 quid.
I had it up on my axle stands and Weber jacks for safety ps got some black chassis paint .
Originally Posted by DaveK
A good question. I have the remote greasing kit fitted. The thing about this is that you can't see when the old grease is pump out. So I'm thinking about not fitting it to my new inner wings and in future just jack the car up to do the nipples. What do others think?
I’m always under my 4/4 checking and cleaning (OCD) the remote grease kit is far easier for me to grease from above, nothing stopping you from bending down after (when you hear the pop sound) for a quick wipe of any excess grease. That’s what I do smile
Craig Jezz
Cut a hole in the gearbox cover and take the pain out of the job.
1972 4/4 2 Seater
Originally Posted by xc68anc
Hello,
why you make a difference between upper and lower nipples?
Both should be greesed about every 1000 Miles. In addition it would be a good idea to have a gaitor
around the springs.
The lower nipples need grease until you see it coming out, but keep attention, overgreasing means to grease
the brakediscs! If you keep attention you hear it with a light "pft".
For the upper nipples: only 4-5 times press some grease in, there is the risk if it's overdone it blocks the sliding.
Sound difficult, be sure, you get the experience!
Drive more with the MOG, so you need more grease, you get the experience!
Greets René
Hallo Werner,
warum unterscheidest Du zwischen oberen und unteren Nippeln? Obere und untere Schmiernippel sollten alle
1000 Meilen mit Fett versorgt werden.
Die unteren Schmiernippel werden gefettet bis etwas Fett austritt (man hört es auch, dann schauen). Dabei
aber nicht zuviel, denn es besteht die Gefaht das Fett auf die Bremsscheibe gelangt. Generell empfiehlt es
sich denn Bereich der unteren Federn mit einem (selbstgemachten) Staubschutz zu versehen.
Die oberen Nippel mit 4-5 Hüben aus der Fettpresse schmieren. Hier kann zuviel Fett die Federung blockieren.
Hört sich kompliziert an, aber keine Bange man kriegt das schnell raus wie es geht.
Mehr Morgan fahren, mehr abschmieren, mehr Erfahrung.
Quelle: Keith von BMH
Anglophile Grüße aus Mainz
René
Thank you René for the hint about the dust protection for the lower spring. I just found it in the book of David Wellings and in his post in TM. How did you build your dust protection?
Danke, René für Deinen Tip mit dem Staubschutz. Ich habe es auch im Buch von David Wellings und in seinem post hier in TM gefunden. Wie hast Du das gelöst?
Greetings from Zürich
Werner
Plus 4 110 Edition 2019
X
X
Hello Werner,
there was a description about the construction here: http://www.talkmorgan.com/ubbthreads.php/topics/601190/2
It's one of the later posts. Today I think I do 50mm instead the 40mm. In cause I'm too silly to post photographs here
I can send it by email.
And also about interest: http://www.talkmorgan.com/ubbthreads.php/topics/598173/not-only-the-kingpins#Post598173
René
es gibt eine Anleitung wie der Staubschutzangefertigt werden kann hier im Forum. Siehe da:
Die Anleitung ist eher am Ende des Beitrags. Heute würde ich von der Waagrechten eher 50mm nach oben gehen statt der 40.
Leider schaffe ich es nicht hier im Forum Bilder zu posten, aber ggf. per Email. Ich habe Dir ergänzend eine PN
geschickt.
Und auch auf dem "Schmierplan": http://www.talkmorgan.com/ubbthreads.php/topics/598173/not-only-the-kingpins#Post598173
Gruß René
2018 plus4 (sports green)
Originally Posted by Spanner Juggler
If you have a pistol grip gun in like a Wanner you can use it sideways on top of the wheel and reach the upper nipple. Then if you listen carefully you can hear it ‘burp’ as the grease exits around and under the steering bearing.
Of course nothing is a good as getting under the car with a couple of 1/2” (13mm) spanner’s and doing a quick spanner check of the lower crosshead/kingpin fixings and tie rod.
BR
Colin (first method is a clean and easy way to give the front a couple of shots of grease when touring)
This is my solution to 'tour greasing' helps with access to the top nipple as Colin suggests above
BR
I also fitted those extensions a couple of years back, following a tip on TM and they make it so much easier to access. Mind you, I still have a belly crawl to make sure discs are clear after greasing.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
