Thought it wise to go out for a shakedown blast before the school run tomorrow.
Since my last run I've fitted new front 4-pot brakes - they pull up pretty well, but obviously the pads need a bit of bedding in. Did some pretty hard braking (on purpose) and back only locked up once, so they seem to be doing a pretty good job.
Rear end has had new 4 leaf springs, panhard rod and bump stops. Really impressed with the back end - now really tight and it makes the steering appear much more positve but that may also be due to the slight raise at the rear? Cornering really well, and far less of the crashing and banging over potholes etc.
Very happy
Engine got a little warm, so stuck the 88 degree stat back in (had a 92 for winter) and adjusted the fan temp 'kick in' and now sits at the right level.
