1 members (Carbuilder),
110
63
Topics49,880
Posts837,761
Posts: 2,539 |
thanks for the photo, mine keeps twisting about 30 degrees.
Posts: 429 |
thanks for the photo, mine keeps twisting about 30 degrees. There are x3 screws
Posts: 371 |
thanks for the photo, mine keeps twisting about 30 degrees. dump it
'16 M3W '44 Willys Jeep '16 Westfield 11
Posts: 2,539 |
thanks for the photo, mine keeps twisting about 30 degrees. dump it i would prefer just to back out the set screw, use a small drill to create a pocket in the shaft, and then locktite the screw.
Posts: 371 |
thanks for the photo, mine keeps twisting about 30 degrees. dump it i would prefer just to back out the set screw, use a small drill to create a pocket in the shaft, and then locktite the screw. imo it just doesn't look right anyway
Posts: 2,539 |
i do like the one that looks more like the button on the parking brake lever. I'm just not spending any more on the car right now.
Posts: 1,671 |
Here's my gear knob/lever similar to that used on the racing D type Jaguars
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
Any clues how to get the gearknob collar off? So far tried taping it and then using a cable tie to get leverage... EDIT - that trick worked second go! Has to be tight as the collar holds the gearknob in the right position in my 2015 version...
Posts: 1,671 |
There’s a small grubscrew which holds the knob it then unscrews - I found tape wrapped around the threaded portion of the mx5 gear lever which I removed to allow the new threaded gear knob to be screwed on
Thanks Mark. On mine the collar unscrewed that allowed the gearknob to unscrew - both from a tube with external threads either end (for collar and know respectively) and 3 grubscrews that pinched an inner separate plastic tube that was over the gear stick. Seemed a little Heath Robinson but it worked!
