1 members (RichardV6), 245 guests, and 56 robots.
+8Rich 62
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,761
Page 4 of 5 1 2 3 4 5
Grockle #400687 19/10/16 01:19 PM
Originally Posted By Grockle
Gearknob late M3W
thanks for the photo, mine keeps twisting about 30 degrees.
kirkusblog.com
1952 Ford 8N
Draggin #400715 19/10/16 02:54 PM
Gearknob late M3W
thumbs
There are x3 screws
Robert
Draggin #400718 19/10/16 03:01 PM
Glenn Offline OP
Gearknob late M3W
dump it
'16 M3W
'44 Willys Jeep
'16 Westfield 11
Glenn #400722 19/10/16 03:05 PM
Gearknob late M3W
dump it
i would prefer just to back out the set screw, use a small drill to create a pocket in the shaft, and then locktite the screw.
kirkusblog.com
1952 Ford 8N
Draggin #400747 19/10/16 04:31 PM
Glenn Offline OP
Gearknob late M3W
dump it
imo it just doesn't look right anyway
'16 M3W
'44 Willys Jeep
'16 Westfield 11
Glenn #400791 19/10/16 06:41 PM
i do like the one that looks more like the button on the parking brake lever. I'm just not spending any more on the car right now.
kirkusblog.com
1952 Ford 8N
Glenn #400814 19/10/16 07:17 PM
Here's my gear knob/lever similar to that used on the racing D type Jaguars
Glenn #639589 23/05/20 09:28 AM
Any clues how to get the gearknob collar off? So far tried taping it and then using a cable tie to get leverage...
EDIT - that trick worked second go! Has to be tight as the collar holds the gearknob in the right position in my 2015 version...
Glenn #639607 23/05/20 09:56 AM
There’s a small grubscrew which holds the knob it then unscrews - I found tape wrapped around the threaded portion of the mx5 gear lever which I removed to allow the new threaded gear knob to be screwed on
Mark H #639631 23/05/20 11:06 AM
Thanks Mark. On mine the collar unscrewed that allowed the gearknob to unscrew - both from a tube with external threads either end (for collar and know respectively) and 3 grubscrews that pinched an inner separate plastic tube that was over the gear stick. Seemed a little Heath Robinson but it worked!
