1 members (Carbuilder), 133 guests, and 36 robots.
John V6 63
My Goodwood Revival 2026
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,940
Posts838,603
Page 8 of 14 1 2 6 7 8 9 10 13 14
I see redthree has gone with #3 that would give me some hope and encouragement if I were you. Always look on the bright side of life as they say.
Gordon Duguid
The loss of power and then recovery points me to No. 4 fuel pump but can't wait to find out the truth.
+1 for the fuelpump.
Red Leader drive
Fuel pump here too, its unlikely the centa would come back to full drive after partial drive ie loss of powerl.. they just keep progressively failing until terminal disintegration
PaulR
Valve spring gone. (had that one myself) spins over won't start.
Number 6
I've had enough of the others to appreciate the differences. Been towed home 5 or 6 times for cam belt failure, dead alternator/rectifier, fuel pump and the failure of the compensator (mine was a 2012 HD thingie). The Centa unit has pulled over 30,000 miles and is behaving. The rest of the car has over 50,000 miles and it shows!
Javier,
You didn’t answer my question if the engine turned over when you try to start after the picnic.
www.m3w-jungfrau-treffen.com
Marmota Offline OP
THE BET CHART GOES AS FOLLOWS
1 - Cambelt failure
2 - Battery dead
Obie
2b - Bad earth from rectifier or battery
PaulV
3 - Rectifier is dead
Sporster
Dap of oppo
Calum (Red Three)
Jon M (CooperMan)
4 - Fuel pump default
Rog G
Phil Bleazey
Red Leader (Chris99)
PaulR
5 - Battery cables not tightened
Laurens
6 - Centa rollers disintegration
Richard (+8RICH)
Ian (planenut)
Gordon (Gordon D)
Joejoe (HalfFull)
Andy (Bunny)
Luddite
nippymog
Michael H
7 - Crank position sensor
8 - Starter motor / solenoid
9 – Drive pulley shearing off the camshaft
10 - Girlfriend’s drawers sucked into the carburettor (I hope the mechanics don't find anything weird in there)
SFG
11 - They all do that Sir
Rob (RobNW)
12 - Valve spring gone
Elcyd
www.speedymarmots.com
Marmota Offline OP
Originally Posted by Laurens
Javier,
Hello Laurens. The sound was like something rotating and clinking, but I assure that the pistons were not moving. The shacking of the engine while the big pistons move is quote obvious (I think). And there was absolutely no movement of the engine. Still and flat as pond water...
On the strength of that you can add me on 6 wink
