Old Book
Topics49,940
Posts838,605
Posts: 1,236 Likes: 40
Posts: 1,236 Likes: 40 |
I see redthree has gone with #3 that would give me some hope and encouragement if I were you. Always look on the bright side of life as they say.
Gordon Duguid 2014 Duratec engine plus 4, Montreal blue.
Posts: 450 Likes: 1
Posts: 450 Likes: 1 |
The loss of power and then recovery points me to No. 4 fuel pump but can't wait to find out the truth.
Posts: 3,740 Likes: 82
Posts: 3,740 Likes: 82 |
Red Leader
Posts: 132 Likes: 1
Posts: 132 Likes: 1 |
Fuel pump here too, its unlikely the centa would come back to full drive after partial drive ie loss of powerl.. they just keep progressively failing until terminal disintegration
PaulR
Posts: 103 |
Valve spring gone. (had that one myself) spins over won't start.
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
Number 6
I've had enough of the others to appreciate the differences. Been towed home 5 or 6 times for cam belt failure, dead alternator/rectifier, fuel pump and the failure of the compensator (mine was a 2012 HD thingie). The Centa unit has pulled over 30,000 miles and is behaving. The rest of the car has over 50,000 miles and it shows!
Posts: 722 Likes: 24
Posts: 722 Likes: 24 |
Javier,
You didn’t answer my question if the engine turned over when you try to start after the picnic.
Posts: 961 Likes: 21
Posts: 961 Likes: 21 |
THE BET CHART GOES AS FOLLOWS
1 - Cambelt failure
2 - Battery dead Obie
2b - Bad earth from rectifier or battery PaulV
3 - Rectifier is dead Sporster Dap of oppo Calum (Red Three) Jon M (CooperMan)
4 - Fuel pump default Rog G Phil Bleazey Red Leader (Chris99) PaulR
5 - Battery cables not tightened Laurens
6 - Centa rollers disintegration Richard (+8RICH) Ian (planenut) Gordon (Gordon D) Joejoe (HalfFull) Andy (Bunny) Luddite nippymog Michael H
7 - Crank position sensor
8 - Starter motor / solenoid
9 – Drive pulley shearing off the camshaft
10 - Girlfriend’s drawers sucked into the carburettor (I hope the mechanics don't find anything weird in there) SFG
11 - They all do that Sir Rob (RobNW)
12 - Valve spring gone Elcyd
Javier,
You didn’t answer my question if the engine turned over when you try to start after the picnic. Hello Laurens. The sound was like something rotating and clinking, but I assure that the pistons were not moving. The shacking of the engine while the big pistons move is quote obvious (I think). And there was absolutely no movement of the engine. Still and flat as pond water...
Posts: 8,718 Likes: 421
Posts: 8,718 Likes: 421 |
On the strength of that you can add me on 6
