Old Book
Topics49,940
Posts838,604
Posts: 488 |
Congratulations to Paul v, glad it was an easy fix for you Javier!
Posts: 79 Likes: 3
Posts: 79 Likes: 3 |
Congrats on a simple fix. I have had both battery terminal bolts back off separately and strand me each time early in my M3W ownership. Now I must go check this starter earthing bolt in a preemptive strike... that one has not got me yet!
Posts: 8,728 Likes: 514
Posts: 8,728 Likes: 514 |
I think there's two winners... First, Javier gets an easy fix, & PaulV for the most accurate diagnosis
Posts: 961 Likes: 21
Posts: 961 Likes: 21 |
Here a question for you Javier, was there a Star washer under that loose lug?
Hello Stephen. We did not removed completely the hex nut, so can't tell you at 100%. But I had a very close look at it, and also have the pictures, and I guess there is none  If I see I can remove it easily in my garage without losing any washer or other small ítem, I might think about putting some Loctite thread locker.
Congrats Javier - good to see it was one of the simplest problems / solutions you found as part of your shakedown trip! I hereby donate your generous prize to your Grindelwald meetup Hello Paul! We all agreed you are the winner as you got it really close!  A deal is a deal. I'll PM you so you give me your address and will see how to send you the bottle!
Hang on - do we know what caused the rectifier to fail? It may have been the Flying Monkeys..... If we make a deep analysis…. and knowing that Flying Monkeys is a US Brewery https://www.flyingmonkeys.ca/ it might happen that the guy who tightened this hex nut had few of these beers before doing it… But how to prove it?  Or the one who tightened the hex nut WAS THE MONKEY??? https://www.youtube.com/watch?v=DbSH_U8AsB4
Posts: 1,671 |
Javier, some owners have run a second earth lead to the chassis. This would save the day regarding this issue but still requires regular inspection.
Posts: 141 Likes: 3
Posts: 141 Likes: 3 |
Well done Marmota, glad it was a simple problem.
Posts: 5,486 Likes: 477
Posts: 5,486 Likes: 477 |
Wonderful news Javier, and such a simple fix too. True to form my thinking was proved to be wrong once AGAIN and to no one`s surprise I guess...(-: The only problem for you now is that you seem have been made aware of all of the many afflictions that can effect a M3W every time you fire it up...ever listening out for unusual noises...! Been there done that in my +8 after years of reading of Morgan maladies before I bought mine, and toured around your country and a bit of France and Italy... Hope you have many similar happy miles ahead..
Posts: 296 Likes: 3
Posts: 296 Likes: 3 |
Happy to hear it is fixed, Javier, and especially that it was not a transmission problem.
Clearly a flying monkey got under your bonnet... (loved that video!)
2020 M3W
