7 members (Morganmike, piquet, Ian Wegg, Robbie, linklaw, Clipper, Alistair),
337
44
Topics49,837
Posts837,291
Posts: 488 |
Good work Lightspeed, certainly started well and will be interesting to hear your views after a road test. Still no sign of oil at the rockers at the end of the video, it’s surprising how long it takes at tick over to get up there!
Posts: 1,562 |
I have roller rockers fitted, over 4 years ago. I cant say it has made the engine any quieter - possibly a tad louder on valve clatter but nothing overly concerning. Performance differnce post fitting is noticable - it is more free revving , on acceleration the revs just shoot up as far as you want with no hesitation. This was with Morgan stage 2 exhausts which were already fitted , and I get the same with the G56 pipes currently fitted. It did have an ECU tune up on a rolling road at the time post fitting , which may have helped , no idea how much though.
Posts: 775 Likes: 33
Posts: 775 Likes: 33 |
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Obie, yes it is surprising how long it takes. I poured oil over the rockers before starting and that was after an overnight soak in oil.
Nippy mog, I have the AR Stage 1 pipes too, but I finished boring out the oem mufflers so I plan to swap to see how it works. Nobody here to adjust the locked ECU so I will see how well the self mapping goes. I suspect that it will work ok but a retune would undoubtedly be best.
The ease of reving was evident just sitting on the lift. Usually it would cough a bit but not now.
Posts: 1,031 Likes: 2
Posts: 1,031 Likes: 2 |
Without an unlocked ECU to at least reflash (but preferably remap), is this not a Stage 1.5 upgrade? Can the factory ECU self-adjust to deliver Stage 2 benefits?
Without an unlocked ECU to at least reflash (but preferably remap), is this not a Stage 1.5 upgrade? Can the factory ECU self-adjust to deliver Stage 2 benefits? Since my nearest dealership is a solid 3 day drive each way I doubt any MMC people will get their hands on the ECU. If I did anything with it I would get an unlocked ECU mapped for the cams already.. We will see how it runs, and after all I was looking for a smooth running engine and not necessarily more power, but I did expect an upgrade in power would happen.
Posts: 79 |
some clear rocker covers would be great!!
1928 Superaero Jap 3 wheeler 2013 5 speeder 3 wheeler
some clear rocker covers would be great!! I was thinking the same thing, but the hazing from heat and hot oil on one side and people touching and wiping it from the outside might make a mess. But is sure would look nice for awhile😊
The stock ECU can not accommodate Stage 2 cams.
The stock ECU can not accommodate Stage 2 cams. In what way? Less power? If so how much less? It sure would be nice if S&S would unlock the ECU...
