2 members (Luddite, Nickplus4),
399
Posts837,284
Posts: 1,031 Likes: 2
Posts: 1,031 Likes: 2 |
KH's ECU is available now at £800 incl reflash.
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
The locked ECUs can only be unlocked by MMC and they won't do that as they are set to meet emissions regulations. Those who had their car supplied with an unlocked ECU were just lucky.
Also if purchasing a new unlocked ECU check it is physically compatible with your car. The wiring loom and connectors are different for EU3 and EU4/IVA cars and I have also heard that there was another change in design earlier this year.
Red Leader
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
So what is the difference between G56 and Krazy Horse products? I didn’t see a number on the ecu but I do know it has the micro USB port under a plate that has 2 ridiculously small screws in it.
KH's ECU is available now at £800 incl reflash. So how do they “reflash” it without the vehicle?
So what is the difference between G56 and Krazy Horse products? I didn’t see a number on the ecu but I do know it has the micro USB port under a plate that has 2 ridiculously small screws in it. All the ECUs come from S&S so they are the same. The G56 and KH maps will be different.
Red Leader
Posts: 1,016 Likes: 2
Posts: 1,016 Likes: 2 |
Chris has explained things well, but just to be clear with what happens with these 'Stage 2' maps that an Unlocked ECU can have. As explained above, an engine that has had improvements made to breathing ability etc (Exhaust, Induction, Cams) will require revised Air:Fuel mixes and Ignition Timing applied to them to get the best from the upgrades. The stock, locked Morgan ECU has some ability to adapt to changes in running parameters (to accommodate varying quality of fuel, temperature, humidity, general engine wear) but these have limited boundries as to how far they can adapt. A Stage-2 engine (ie: one that has all 3 elements mentioned upgraded) needs a new base configuration that better suits the fact that the engine can now breath properly (the standard engine is heavily restricted). Not only will this keep the engine working at its best, but the same adaptive process can continue to do its magic but with the revised boundary parameters that it needs. That's all well and good.
Both G56 and KH will know what map is needed for the typical Stage-2 engine setup and will supply an Unlocked ECU containing that map, running paramters and ability to adapt. Think of this as a 90-95% perfect solution. Most Stage-2 engines perform the same so a G56/KH Stage-2 ECU will do a perfectly acceptable job. If however you want to maximise the benefit of your hard-earned upgrades, then you can elect to have the now Unlocked ECU setup to PRECISELY match your specific engine and environmental conditions. A qualified and experienced Dyno operator will be able to put YOUR engine under differing loads and adjust the 3D Fuel/timing maps to suit that specific engine. The result is that you then have an ECU setup that 100% matches your engine, rather than 90-95% hit. Will you notice the difference? If you're into your engine setups big time, then yes, but plenty wouldn't notice the difference for what might be a £200-300 dyno and setup session. Are you missing out if you get your Stage-2 ECU by post and simply plug ity in? Err, no, not much in all likelihod.
Hopefully that makes sense for those comtemplating Stage-2 ECU-ness in distant lands and without access to the experience and ability of a local S&S specialist with a dyno that fits a tricycle.
Posts: 1,562 |
Just to throw another variable in which I havnt seen mentioned in this thread , when I did the stage 2 Morgan upgrade , it came with an unlocked ECU letting me , and the tuner I used tweak it futher as required. I suspect , and have never read otherwise, all Morgan staged upgrade ECU's are supplied open. I have no idea if third party ECU's do this, worth checking before purchase. Its possible they could load their map then lock it.
Ringa , good points and something I suspected.
Nippymog, that indeed would be a good question to ask! Thanks for the thought.
I quoted a UK price, including VAT. I think the price for export to the US would be c.£680+$60 US tax (plus shipping).
Great explanation R1NGA  I would add that once you've run your unlocked ECU mapped car for a while then, as 2Sharp says, it's worth blending the adaptive map into the base map. This allows more adaptive range and I found the engine runs better. If you do this don't forget to save a copy of your original base map first so you can revert if you need to.
Red Leader
