8 members (RichardV6, Sir Percival, Burgundymog, TBM, KLASG, moggywills, Bishmog, Colin_Mackay),
215
52
Posts837,944
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Removed mine the first week I owned the car, never looked back.
It is sitting in a drawer now waiting for me to ignore it :-)
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
It sure is exasperating needing fuel and struggling to get to it! The funny part about it is that is the nicest looking key out of the three that came with the vehicle. I will play with it just so long and then probably rip it out for another more reliable item. Morgan strikes again!! Stephen, My Plus 4 was exactly the same however it became a little better with a thin smear of waterproof grease, the white sort you use on boats.
Posts: 1,562 |
My locking fuel cap goes very stiff at times and wont turn , lots of WD40 and unneccesary force has freed it up to date, praying the key doesny snap off.
Posts: 934 Likes: 12
Posts: 934 Likes: 12 |
Same problem on 2 of my 3 4 wheeler Morgans , The locks are in the glove box now .
stefan
+4 +8 ARP4
It sure is exasperating needing fuel and struggling to get to it! The funny part about it is that is the nicest looking key out of the three that came with the vehicle. I will play with it just so long and then probably rip it out for another more reliable item. Morgan strikes again!! Stephen, My Plus 4 was exactly the same however it became a little better with a thin smear of waterproof grease, the white sort you use on boats. That was going to be my next try, just a wee dab of lithium white grease smeared around. Being hard to get it out is one thing but having the key pull out no matter what rotational position could ultimately kill it. Nippymog, that would be a nightmare to break off the key in it😱😱😱
Posts: 365 |
I vote for a little downward pressure as well.
2017 M3W Sport Green
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
A squirt of ACF-50 or WD-40 into the keyhole works wonders.
If not just run without it.
Red Leader
OK, tried a little downward pressure, nothing. I tried a wee smear of white grease and it helped a bit but still sticky. Tried a bit of WD-40 and nothing but when I switched to PB Blaster which has a thicker oil component it helped take the squeak out.
It all helped but still not great so I investigated the aluminum recess in which the cap resides and found that it was only finished smoothly on the part you can see. The underside of the lips inside the fuel fill neck was very rough so I put some white grease under there and that was the magic solution. I know it will not last long because the rough aluminum still exists so until I feel comfortable enough to burnish the inside of those lip, probably by removing the neck to do it, the cap will sit in a drawer.
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
+1 Kankel
Took mine out and never refitted it.
