Topics49,904
Posts838,076
Posts: 104 Likes: 18
Posts: 104 Likes: 18 |
I was fiddling around with a cardboard box. I glued a plate of wood and a T-shaped piece of metal on it. It is clamped into one of the rectangular holes of the radio mount. It sits really firm. Since I have no radio I removed the radio blind. Next step: Building a wooden tray and trim it with leather. Clamp it with two plates instead of one. Caveat: It only works for LHD Morgans, because of the reachability of the handbrake. IMG_2317 (1) by Werni Wehrli, auf Flickr IMG_2322 (1) by Werni Wehrli, auf Flickr IMG_1296 (1) by Werni Wehrli, auf Flickr
Plus 4 110 Edition 2019
Posts: 28,911 Likes: 354
Posts: 28,911 Likes: 354 |
Neat idea. As for only being suitable on left hand drive Morgans, that depends on which side the hand brake lever is - my present car has it on the right hand side of the tunnel  However, on my other two where the handbrake was on the left, it was easiest to reach around the back of the gear lever to apply the brake.
Posts: 939 Likes: 21
Posts: 939 Likes: 21 |
Neat idea. As for only being suitable on left hand drive Morgans, that depends on which side the hand brake lever is - my present car has it on the right hand side of the tunnel  However, on my other two where the handbrake was on the left, it was easiest to reach around the back of the gear lever to apply the brake. Graham, I’ve queried the positioning of the handbrake lever several times as it’s on the left of the gear stick on my +8 but I have seen a number on the right of the gear stick and it’s right hand drive. Was it just preference when ordering the the car from the factory?
Nope. I think you'll find it depended on the engine (and gearbox). 1.8 Zetec are on the right hand side (not been in a Duratec). When I first bought this 4/4 I regularly reached around the back of the gear lever, only to remember the handbrake was closer to me!  Both my '97 +4 Rover M16 (IIRC) and '76 4/4 X-flow had handbrake on left of tunnel.
Posts: 27,840 Likes: 764
Posts: 27,840 Likes: 764 |
Correct Graham, my 97 +4 and the Roadster are on the left. I can't remember on my 94 4/4. John
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
On my 1.8 2007 duratec it's on the left.
Posts: 2,583 |
4/4 sport - on the left.  reckons it was designed by a pervert as the driver`s hand comes into contact with the passenger`s leg when applying the handbrake - she should be so lucky. However if I had a different passenger of a newer model it might be more interesting.
Posts: 9,554 Likes: 134
Posts: 9,554 Likes: 134 |
2002 Plus 8 has it to right and just forward of the gearstick. The opposite of your layout.
I remember seeing a Caterham with a removable saddle style leather centre console cover that had a couple of storage areas. There were also a couple of elastic nets on the footwell side for storage.
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
On the left in my 2003 Black top Zetec 4/4. That’s a neat solution to add some accessible storage.
Bud 4/4 "Stanley"
Posts: 383 Likes: 6
Posts: 383 Likes: 6 |
Regards
Geof 70th Anniversary 4/4 (Duratec 1.8), model 1995
