0 members (), 297 guests, and 100 robots.
+8Rich 78
Topics49,872
Posts837,704
Rudolf
#647726 30/06/20 09:48 PM
linklaw Offline OP
I did my first oil change today on my 2016 Superdry Edition at 1000 miles. I used an oil vacuum to evacuate the reservoir, emptied the sump, cleaned the magnetic drain plug and changed the filter. After draining the reservoir, I replaced the drain bolt with a quick drain spigot. Filled her up with 6 quarts of Mobil 1 V Twin 20w50 and started her up. No leaks, no strange noises. I saw a small amount of magnetic gunk on the drain plug. It looked normal for a new engine. The only small hitch was I burned my elbow on the hot exhaust while spinning the filter off. Long sleeve shirt next time should solve that problem. The next change should even be easier with the quick drain spigot. Off for a ride now.
John Linkosky
1995 4/4
2005 Roadster
2016 3W Superdry Edition
Not sure why you would want a quick drain spigot on the sump (potential problem too), much easier to fit a drain on the oil feed line then no need to vacuum evacuate the reservoir?
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
I have a quick release valve at the tank and clamp tubing to the quick release valve and drain the tank directly without mess or much effort. I only hand tighten the oil filter so never need a tool to remove it.
Emil at morgancustom.net sells an excellent in-line oil drain. Cannot beat it
linklaw Offline OP
I installed the drain valve on the oil reservoir, not the sump. Misstatement on my part.
John Linkosky
1995 4/4
2005 Roadster
+1. And I will second KankeL’s recommendation, I use it since it is the lowest point t in the system and drains that hose as well.
I have the easy spigot as well. Beats having to climb under the engine... I say climb.... more like get down into a position from which I cannot recover
Rodger
2004 Plus 8 (wife's)
rcmatt #647814 01/07/20 12:28 PM
Think LIFT, it sure helps with these vertically challenged little things.
kankeL #647947 01/07/20 09:51 PM
+1. And I will third KankeL’s recommendation
2018 S&S 110th Beetleback
1934 MX4 Beetleback (in restoration)
1965 Corvette Coupe 327/350
kankeL #653692 01/08/20 03:32 PM
How difficult is it to install Morgancustom.net oil drain ?
Procedure ?
Dutch Junge
194 Mound St
Logan, OH USA 43138
2012 3 Wheeler
1980 + 8
