2 members (Socalm3w, sprinty),
336
53
Topics49,844
Posts837,360
Posts: 8,664 Likes: 408
Posts: 8,664 Likes: 408 |
Even the Velocette is not foolproof though. The check valve in the pressure pump feed line takes the form of a ball on an inverted seat requiring a spring to hold it closed. Pump suction once the engine is running defeats the spring and allows flow from tank. The suction will only be adequate to achieve this when the oil lines are full however so always a little worry after an oil change, although generally only a concern after a rebuild when line must be primed.
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
Phil, I have a similar problem but no visible leaks. The car has been standing for some four months due to lockdown / shielding and being some 4 miles away. I did sneak there the other day and the car would'nt start, the starter just clicking as if the battery was flat. I fitted the charger and it showed 14.7 volts. Checking the oil it was way under minimum so I presume wet sumping. I shall try a battery pack in the next few days and see if a boost helps, otherwise drain the oil and refill the tank.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
Steve Late 2012 M3W
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
That Dudley idea sounds good.
Posts: 450 Likes: 1
Posts: 450 Likes: 1 |
The magneto guys get my vote and when they have some in stock I think I will get two - one for the Morgan and one for the Velocette. Thanks Bitsobrits.
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
So: does anyone undo the breather from the air inlet and redirect to a bottle if wet sumped and starting the M3W?
