2 members (Black Adder, Luddite), 210 guests, and 26 robots.
+8Rich 96
John V6 51
Topics49,900
Posts838,037
#64533 08/07/11 06:55 PM
What are the things I shouod attend to as part of a routine yearly service on my plus 4...oil change,kingpins,brake pads/shoes.what else?
nothing matters very much, and hardly anything matters at all.
Dave P. Bologna red + four
South Wales Correspondent
Depends how OCD you are.
I also check:
plugs and leads ( Magnecors in my case, so low risk area),
air filter element,
Coolant level and strength ( in fact I change mine very year),
all hoses and joints,
I assume you'll look at oil filter element when you consider oil change.
If car is any age, what about your auxiliary belt ( ie alternator)?
You might also want to look at tightening various bolts/nuts etc because we are talking here about a car with a separate chassis which will flex and loosen all sorts of things
GLLHG
PS On a personal level,I'd also check things such as brake fluid strength, diff oil and gearbox oil but wouldn't consider these as routine ( ie yearly) things.
GLLHG
GLLHG #64540 09/07/11 08:17 AM
G, your mention of the air filter makes me ask the additional question of when an ITG filter should be changed for a new one. I regularly clean mine but I have had it for nine years. Meabh.
meabh #64552 09/07/11 03:21 PM
I've seen blurb which claims that the ITG TriFoam filters can last up to 15 years but on a personal level, I'd be loath to keep one that long- even with regular washing.
As to the washing/re-oiling, I work on about 8-10,000 miles but again, I've seen longer intervals recommended
It really is very important NOT to overoil them though
Before I fitted the ITG I looked hard at all the options ( K&N, Green, Pipercross etc) I was very taken with BMC's Carbon Dynamic Airbox but I couldn't find a way to package it
For my money, ITG's closed system Maxogen is the one to go for- but at the end of it all, it's a very personal thing and the dyno don't lie
regards,
GLLHG
GLLHG #64555 09/07/11 03:57 PM
Thanks G, probably time for a new one then. M.
meabh #64556 09/07/11 04:15 PM
Changing out brake fluid can be a real benefit.
'65 +4 four seater
I agree. because, of course, brake fluid is hygroscopic, the water it attracts can quickly lower its boiling point.
I recently replaced all the flexible brake hoses on my 4/4 with Goodridge s/s braided items so it gave me a good chance to drain and clean the system thoroughly.
I tend to do it every one or at most two years but I have seen a number of vehicle maintenance manuals which recommend annual changes as essential
Cheers,
GLLHG
GLLHG #64560 09/07/11 05:35 PM
Brake fluid must be every two years.
Go Mog has a service guide which might help
http://www.gomog.com/allmorgan/GoMogServiceList.html
Good luck
thumbs
John V6 #64561 09/07/11 06:36 PM
It's much easier if you use a fluid transfer tool to empty the master cylinder first which saves pumping all the old fluid through the system. With MogMileage, two years should be OK.
DaveW #64565 09/07/11 09:20 PM
Hasn't every garage got one?My Draper model has had pride of lace on my shelf for years ( Mind you, might be something to do with having to bleed MG systems!! ooo
Cheers Dave
GLLHG
