1 members (sprinty),
279
58
Topics49,860
Posts837,486
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
Try Dynabeads, every time you drive above 30mph they re-ballance themselves, and not ugly weights on the wheels.
Posts: 557 |
Try Dynabeads, every time you drive above 30mph they re-ballance themselves, and not ugly weights on the wheels. Do you hear any noise from them at low speeds?
Posts: 1,075 |
Just a bit of advice that's worked for me for over 50 years of changing out tires and tubes on small to larger motorcycles. When you have the first bead into the wheel and you insert the tube and get the stem through the wheel and the nut just started on the tip, put just a little air in the tube to inflate it round. This eliminates any flat flaps in the tube that always seem to get pinched when you put the second bead into the rim. It's not idiot proof, but this idiot has pinched a LOT less tubes since using this little trick of inflating the tube "just a bit" before the second bead gets worked into the rim. And yes, three hands helps a lot...
Dan
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
Dan.... I finally bought a stem puller, which is a games changer as well
No noise from the Dynabeads, they are really small as they are inserted in via the valve stem.
Posts: 365 |
What size stems are you using for the tubes for your Morgan?
2017 M3W Sport Green
Posts: 775 Likes: 33
Posts: 775 Likes: 33 |
I had a very poor experience with Dynabeads. The shop that works on my M3W ( combined high performance motorcycle and Indian dealership ) swears by Dynabeads and put them in the tubes when they put new tires on the front. My steering wheel shook so bad at speed. Clearly my wheels weren’t balanced. They must have put in too much, I don’t know. Had to put in new tubes and balance the traditional way. I’m glad others have had a good experience but I’m not risking it again.
I emailed Dynabeads with the tyre size and fitment they worked out the quantity and I ordered that amount.
Thankfully no problems even with 2 tyre changes.
Posts: 557 |
Thankfully no problems even with 2 tyre changes. How much should I order?🧐
I think 2 sharp has asked several times what tubes are people stateside running? (I would like to know as well)
