6 members (RubyMog95, Graham, G4FUJ, Montegue, Image, Biggle, MATTMOG),
296
85
Topics49,859
Posts837,477
Posts: 697 Likes: 7
Posts: 697 Likes: 7 |
I have a wanner and it’s great. The only downside is you have to fill it up manually as it does not take cartridges. I tried a cartridge gun but is was no way as good as a wanner
Posts: 6,669 Likes: 433
Posts: 6,669 Likes: 433 |
I have a wanner and it’s great. The only downside is you have to fill it up manually as it does not take cartridges. I tried a cartridge gun but is was no way as good as a wanner i knicked one of the teaspoons to help with filling. Now lives in the shed
And there's not a grease nipple on the Morgan that I can't reach with the Wanner.....
Posts: 697 Likes: 7
Teaspoon, now there’s an idea I have to try
Posts: 5,465 Likes: 171
Posts: 5,465 Likes: 171 |
Castrol (& other) grease comes in a plastic pot with a mega washer in the top. The mega washer has a 12mm diameter hole. Simply place the open great gun over the hole and push down. In seconds the grease gun is full. A slide to one side to finish off the fill and a minimal wipe over required before re-fitting the top of the gun. All you need to do then, with a pistol type gun, is to bleed out the air. Simples.
Posts: 37,416 Likes: 977
Posts: 37,416 Likes: 977 |
+1 Comma or Castrol.
I was struggling with the need for a teaspoon.
Posts: 1,633 Likes: 62
Posts: 1,633 Likes: 62 |
Red and tacky for me too, and I just use a little pistol grip gun clean and compact
99 plus 8 indigo
Posts: 1,616 Likes: 142
Posts: 1,616 Likes: 142 |
Can't be arsed spooning grease out of a tub into a grease gun.
Worked on heavy plant and forestry machinery which needed daily greasing else the link pins would wear the holes oval. If I had to use a Wanner, it would need filling up several times, be mid morning before I started processing the timber.
Lever action cartridge gun every time for me with a flexi hose.
Arwyn
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
I use 'pin n bush' grease also via a £13 Chinese made lever action gun with flexi hose. Works better than anything else I've ever used, including Wanners.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
I tried one of those washers from another grease pot (and which work perfectly with most greases) but the 'red and tacky' was just too 'tacky' and couldn't get it to fill properly. Bearing in mind that I've filled my grease gun about 5 times in the last 18mths, I can live with the 3 minutes it take with the spoon. I usually pull the plunger down a few cms, stick a few spoonfuls in, then pull down a few cms and repeat. Gets it cram full.
If I was greasing on an industrial level like Arwyn, then I'd go to cartridges as well!
The joy of the Wanner for me, is by swivelling the tube I can get it into knooks and crannies that I couldn't get my flexy hose in, as the gaps not big enough to get my hand in - front propshaft nipple comes to mind, and I can get it into the rear axle nipples by threading in between brake lines and handbrake bars without having to remove the wheels.
