10 members (RichardV6, Image, Graham, G4FUJ, Sir Percival, HKNYMOG, Gordon D, Rovert, MartO, IcePack, Montegue),
159
48
Topics49,846
Posts837,375
Posts: 27,807 Likes: 749
Posts: 27,807 Likes: 749 |
Went to Caister Castle car museum with the Great Escape Gang. Great fun even if it rained a lot.
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
Stripped the front hubs to check the bearings were set up & lubed correctly, so of course you have to follow it up with a test run  ![[Linked Image]](https://www.tm-img.com/images/2020/07/10/David-Mellors-3.jpg)
Posts: 1,615 Likes: 1
Posts: 1,615 Likes: 1 |
SFG 2012 4/4 Sport
Posts: 37,407 Likes: 977
Posts: 37,407 Likes: 977 |
Stripped the front hubs to check the bearings were set up & lubed correctly, so of course you have to follow it up with a test run  ![[Linked Image]](https://www.tm-img.com/images/2020/07/10/David-Mellors-3.jpg) Your car looks splendid Jon, where is that interesting looking building ?
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Went for the MOT today, it didn’t pass & it didn’t fail.......I was told its booked in for the following Friday  ![[Linked Image]](https://www.tm-img.com/images/2020/07/10/0E9A381B-6E2F-4D58-962F-53CC0B8DB1D4.jpg)
Craig Jezz
Posts: 901 |
Went for the MOT today, it didn’t pass & it didn’t fail.......I was told its booked in for the following Friday An extreme case of setting off early, better luck next week!
Rob
Posts: 2,116 Likes: 68
Posts: 2,116 Likes: 68 |
Went for the MOT today, it didn’t pass & it didn’t fail.......I was told its booked in for the following Friday An extreme case of setting off early, better luck next week! Did you need a reason for a trip with your 4/4?
Posts: 82 |
The Round Building, Leadmill, Hathersage. Nice coffee
It seems to be a cutlery factory Round building
Thanks John, I like that building a lot.
