2 members (DaveK, +8Rich),
346
45
Topics49,904
Posts838,087
Posts: 378 |
The drivers rubber door seal on the SuperSports isnt in the best of conditions and really needs replacing. Does the factory still "support" the model or does anyone knows other avenues of supply? many thanks T
15 Weissman GT5 11 Aero8 SS 21 Q7 23 RR 24 Def'r 130 1960 XK150 DHC 1970 E-type 2024 Huracan Tech
Posts: 2,439 Likes: 71
Posts: 2,439 Likes: 71 |
Try car builder solutions Taffy.
Em
Posts: 1,508 Likes: 57
Posts: 1,508 Likes: 57 |
Two questions  1. can you make me a picture of the door sill? Do you have "something" on the door itself? 2. if you see something online, please put the link here as well
Posts: 8,701 Likes: 501
Posts: 8,701 Likes: 501 |
If you peel the joint apart you should be able to measure the size of the bubble / fixing lip and identify it, knowing MMC it will be some std generic seal (probably off an old Mini  )
Posts: 2,583 |
Try Seals + direct - they will send samples so you can be sure you have the right one.
