Clutch weights are, as removed and unclean
Flywheel.........3.156kg 7lb 2 oz
Friction plate...0.900kg
Clutch Cover set...2.212kg
Size is an issue for any nonstandard unit. Bell housing to centre of shaft is approx 140mm so 280mm dia
Current clutch cover is around 230mm dia
Current unit friction plate is 184mm which is quite small compared to common standard units
At present I am leaning to go with the status quo to retain originality ?.
I have been in contact with CG and they will rebuild but not sell diaphragm on its own. I am somewhat concerned with sending clutch around the world, from both a cost and risk of being lost or damaged point of view.
Difficulties of being in the colonies, sigh
Anybody know what the torque specifications are for the current unit?
