Topics49,866
Posts837,588
Posts: 15 |
Hello all,
I was recently given a link to this forum and have lurking about the edges waiting for a reason to join which has now come up
I installed a Tornado chip in my '98 +8, GEMS NAS car last April and was preparing the car for a followup dyno run as I have over 3k on the new chip when I noticed via my Nano printouts that the pre-cat O2 sensor on bank 1, odds, read 6.17 while the bank 2, evens, read 0.37. I am not sure what the numbers mean but suspect I have an O2 problem. The car seems to run just fine but would like the O2 question resolved before putting it on a dyno.
Thanks all and looking forward to learning more from the group. I live in Portland, Oregon, and am a bit on my own with this car which I have had for just under 3 years. My first Morgan.
Thanks again, Skip # 12034
Posts: 15 |
Hi Folks,
I just talked with a fellow that understands modern ECU EFI systems and I appear to have posted my question to quickly. I guess O2 sensor activity needs to be looked at over time rather than for an instant. I also had a series of Fueling readings over about 1 minute and see that both sensors cycle up and down from about 0.22 to about 6. I would have a problem if one of the sensors did not change at all.
Now it is time for a G&T.
bye, skip
Posts: 4,612 Likes: 15
Posts: 4,612 Likes: 15 |
Good Morning Skip, and welcome to TalkMorgan  There is nothing nicer than resolving an issue yourself  keep posting, others could always have the same issues.
Posts: 478 |
Skip, Normally if you have an 02 Sensor problem it would show on the MIL light, however I have a sneaking suspicion that the MIL light is disabled on the Tornado chip (anyone know?) However if you have a problem, then the engine would not be running correctly. As you seem to have a diagnostic unit can you check the operational mode which should be running closed? if so the 4 sensors and the heaters have passed all the diagnsotic checks. Alas here the sum of my knowledge ends, so not too helpful I'm afraid. If you have not seen it, I would browse through David Poole's Truly Excellent Gems Guide Brian
Posts: 15 |
Brian,
I have a copy of Poole's opus on both of my computers and am in and out of it frequently. It has been a big help. As I noted in my second post, I over-reacted to a slice of information I from the Nano. It did occur to me that the MIL light was not on and the car otherwise was running well but still I was alarmed. Once a more knowledgeable individual explained to me how the O2 sensor loop works ie the fine points of how it cycles. With that understanding and a print out of the raw data, not easy to read, it was obvious that I had no problem.
I am pretty sure that the Tornado chip is not disabled.
Skip
