9 members (JMcL, Grumpy2, G Walker, RichardV6, Vansrv6, PaulJ, Plus Four Guy, David Royce, JohnHarris),
211
45
Topics49,886
Posts837,870
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
Hi, Stewart, maybe I missed it in the thread and I read it again, do you have a remote control with the Pioneer Radio? I wanted to google if there is the same quality of head unit from Pioneer, but without CD drive?
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Hi, Stewart, maybe I missed it in the thread and I read it again, do you have a remote control with the Pioneer Radio? I wanted to google if there is the same quality of head unit from Pioneer, but without CD drive? Yes there is a small IR remote that comes with the unit which is handy - haven’t used it yet as I haven’t properly set it up. I’ll do a full eq set up when I have the sub in I don’t know whether there is a similar unit without the CD, I didn’t look as I still want to use a CD player occasionally
Posts: 128 |
Hi, I had this issue with my MOG (Marty), I elected for the Blaupunkt Bremen SQR46 (DAB), which is a classic look, traditional high quality radio with 2 x usb ports (No CD) and many features, also comes with remote (necessary to avoid crashes when seeking to change stations or tracks).Not cheap at around £395 but quality isn't!! Looks great when fitted and when I had my centre armrest made up I had a depression built in to house the remote!!! John -------------------------------------- 2011 Plus 4 with modifications
Just before I took my Mog into Lifes to sort a misfire problem, I made a bit of headway fitting the subwoofer I pealed back the carpet and fitted some Dynomat behind where the sub woofer is destined to fit and also on the floor under the footwell mats Holding up and drilling for the sub mounts looked tricky so I made a card template instead so I could be a bit more accurate While the Mog is at Lifes I’ll solder up my leads and connections ready ![[Linked Image]](https://www.tm-img.com/images/2020/08/05/F9C61AE1-3529-4079-A65C-996E17515F77.md.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/08/05/51D9669D-2808-4CF3-9B2D-2F497BB2CE1A.md.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/08/05/B56CD171-2DB0-4FA5-AB68-F1F30ADF40A6.md.jpg)
Well I got my Mog back from Lifes on Friday - all OK and running sweetly So yesterday I spent most of the day finishing off the subwoofer installation. Fed the power back to the battery so I don’t overload the existing 10amp supply to the head unit. Managed to conceal the wire all the way through the cockpit by unscrewing the carpeted trim bits and tucking underneath Still a bit of tidying up of wires to do and I’m going to set my crossovers in the amp this morning before I head off up to Lowther Castle for a picnic with FellMog I’m thinking of setting the filter crossovers between the sub and speakers at 125 Hertz - what so others think? ![[Linked Image]](https://www.tm-img.com/images/2020/08/09/C90203FB-BA98-43C8-8480-E4BF2655E326.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/08/09/E381E197-8201-4B11-AB76-B7D3121B301F.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/08/09/60C3C789-A1EE-4D61-90C2-39FAD8F69673.jpg)
Posts: 5,592 Likes: 609
Posts: 5,592 Likes: 609 |
Not sure about the wisdom of a sub-woofer old chap! .... probably fine for the country album but might be wise to stay away from King Crimson .... shake every joint on your ash frame loose !!  Looks like a good setup .... bet it sounds great. K
All installed with carpet back in I put some black acoustic carpet on the bottom of the sub so it’s very discrete, in fact I can’t see it at all when casually looking in the footwell I put the gain controller strapped to the roll bar It sounds fantastic, really pleased https://www.tm-img.com/image/kXU0Chttps://www.tm-img.com/image/kX5CQhttps://www.tm-img.com/image/kXZYKhttps://www.tm-img.com/image/kX4r6 https://www.tm-img.com/image/kXDja
Don’t know what’s gone wrong with the images But this is the one that didn’t load ![[Linked Image]](https://www.tm-img.com/images/2020/08/09/9F42B271-0B65-488F-91C5-024EBA8FEEAB.jpg)
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Tidy job Stewart well done
Craig Jezz
Nice unobtrusive job for so much sound.... needs a good test run to your favourite soundtrack to bed it in now!
