1 members (+8Rich), 326 guests, and 93 robots.
+8Rich 78
Topics49,872
Posts837,705
Cut the oil line under the car, drain oil, install the in-line oil drain, tighten clamps. Very easy.
Dutch #653697 01/08/20 04:17 PM
Originally Posted by Dutch
How difficult is it to install Morgancustom.net oil drain ?
Procedure ?
I am helping Emil with his installation guides. Have paused right now due to 115F+ temps but will be back on it when it cools off.
I have this mod to do myself and it looks very simple. He did finish the detailed installation guide for this so best to contact him direct.
2018 S&S 110th Beetleback
1934 MX4 Beetleback (in restoration)
1965 Corvette Coupe 327/350
Emil's installation guides are very clear and easy to work through, the oil drain installation as KrankeL says is very simple and easiest install.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
What holds the oil drain valve in position? Or is it just suspended between the lines?
Landy #653928 02/08/20 10:10 PM
The drain is a screw plug into the light weight block which has two male connectors to go into the ends of the pipe which are then clamped tight. If you go Emil's site you can see pictures of it:
www.morgancustom.net
Bruce
2013 M3W (Olga)
This is mine with extra zip ties.
