6 members (Morganmike, RichardV6, Luddite, BLUE+4, GrumpyPa, TBM), 196 guests, and 72 robots.
+8Rich 71
Luddite 47
Guess the car
by Soleng - 07/09/26 06:44 PM
by +8Rich - 07/09/26 06:43 AM
Some real stars on here
by +8Rich - 07/09/26 02:42 AM
European Bike Week
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,886
Posts837,860
Interesting, Fault codes are always a baffle. I had the EML on for the first time today- different engine, RV8, I think I slipped off the key at start up, and there was a noticeable detonation sound presumably back through the intake. Non starter for the second attempt, but a calm intake of breath and she breathed into life again, and seemed to run fine, so onward to home. My generic OBD reader showed
EML FAULT CODE ECU E8 : code P0340 Camshaft position sensor "A" Circuit (Bank 2 or single sensor), so I cleared it and so far so good. Will see if theres any trouble tomorrow. Multiple codes is intriguing, do let us know if the gaskets are the issue. 🤞
06 Saab 93
Will do
Hope it gets sorted soon Stewart !!
Wow that is a lot of codes. The exhaust manifold gasket to the cat failed on my S1 Simon. I hope it is that. You can feel the leak and in my case see it as the heat shield around the clutch master cylinder was being moved by it.
On my car it just caused rough running but no error codes.
