9 members (JMcL, Grumpy2, G Walker, RichardV6, Vansrv6, PaulJ, Plus Four Guy, David Royce, JohnHarris),
211
45
Topics49,886
Posts837,870
Posts: 586 Likes: 21
Posts: 586 Likes: 21 |
Interesting, Fault codes are always a baffle. I had the EML on for the first time today- different engine, RV8, I think I slipped off the key at start up, and there was a noticeable detonation sound presumably back through the intake. Non starter for the second attempt, but a calm intake of breath and she breathed into life again, and seemed to run fine, so onward to home. My generic OBD reader showed EML FAULT CODE ECU E8 : code P0340 Camshaft position sensor "A" Circuit (Bank 2 or single sensor), so I cleared it and so far so good. Will see if theres any trouble tomorrow. Multiple codes is intriguing, do let us know if the gaskets are the issue. 🤞
"DOT" 35th Anniversary Edition Plus 8- family owned from new. Rolls Royce Pewter. 06 Saab 93
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Interesting, Fault codes are always a baffle. I had the EML on for the first time today- different engine, RV8, I think I slipped off the key at start up, and there was a noticeable detonation sound presumably back through the intake. Non starter for the second attempt, but a calm intake of breath and she breathed into life again, and seemed to run fine, so onward to home. My generic OBD reader showed EML FAULT CODE ECU E8 : code P0340 Camshaft position sensor "A" Circuit (Bank 2 or single sensor), so I cleared it and so far so good. Will see if theres any trouble tomorrow. Multiple codes is intriguing, do let us know if the gaskets are the issue. 🤞 Will do
Posts: 2,310 Likes: 5
Posts: 2,310 Likes: 5 |
Hope it gets sorted soon Stewart !!
Posts: 27,827 Likes: 754
Posts: 27,827 Likes: 754 |
Wow that is a lot of codes. The exhaust manifold gasket to the cat failed on my S1 Simon. I hope it is that. You can feel the leak and in my case see it as the heat shield around the clutch master cylinder was being moved by it. On my car it just caused rough running but no error codes.
