Topics49,918
Posts838,246
Posts: 1,707 Likes: 36
Posts: 1,707 Likes: 36 |
Hannes I’m not familiar with Sigma but believe it might use the Ford embedded PATS 2 immobiliser just like the Duratec. If so I would suggest cleaning fuse number 7 (of 8).
On the Duratec fuse 7 is a heavy 20amp fuse that keeps the ecu memoray alive and the immobilser awake when the ignition is off. The current draw is minute at sub 10mA so the big fuse might just be in need of a scrub up. Worth a shot maybe…. Good luck anyway.
Roger 2011 Plus 4
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
I wouldn’t be surprised if the new transponder has to be programmed to the immobiliser unit otherwise it makes a joke of the immobiliser if all a thief has to do is unplug the harness and plug in the transponder he carries in his pocket with a matching key?
BR Colin They told me the new transponder reads the key (same way as the old did) and transfers the data to the car electronics, therefore no new programming as the immobilizing is not in the transponder ring or key but in the car system. Therefore dismantling the ring does not help against immobilizing. So I was told. If it is true, I don't know
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
BR Colin They told me the new transponder reads the key (same way as the old did) and transfers the data to the car electronics, therefore no new programming as the immobilizing is not in the transponder ring or key but in the car system. Therefore dismantling the ring does not help against immobilizing. So I was told. If it is true, I don't know Actually that makes a lot of sense. The Ford EEC4 system was like that but I lost product knowledge after that as I moved on to Volvo Guard systems when we developed our own. If the transponder is just a conduit between the key chip and the immobiliser unit then yes everything you have been told makes sense. Fingers crossed it’s sorted for you soon. BR Colin
Just to close this case:
The car was at the Morgan service station. Back to normal now. An electrical relais was out of function. No further details disclosed as the mechanic had his lunch brake when I collected the car.
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
Posts: 383 Likes: 6
Posts: 383 Likes: 6 |
Thanks for the update. Info now in memory bank. Glad car is ok
Regards
Geof 70th Anniversary 4/4 (Duratec 1.8), model 1995
Posts: 22,375 Likes: 354
Posts: 22,375 Likes: 354 |
I did an unexpected field test this morning. I needed the ignition key in place to turn the steering.
The immobiliser went off immediately, and with the key in place does two flash, then one longer flash every 30 seconds or so.
When I eventually came to start up, there wasn't enough in the battery.
What this tells me is that the immobiliser isn't voltage sensitive, it's temperature sensitive. Now its warm it functions reliably.
Posts: 793 Likes: 144
Posts: 793 Likes: 144 |
I experienced this issue with the ignition key in place failing to activate the immobiliser and the LED dash light remained flashing.
The sensor ring was moved closer to the end of the lock barrel and this worked initially. However, after a few months the issue returned. Eventually the hole in the plastic cowl was enlarged such that the ignition key almost touches the sensor ring. This worked and the flashing LED has been immediately extinguished on insertion of the ignition key every time for the last 6 months.
Of concern is what happens should this issue resurface. I am not convinced the root cause is the proximity of the sensor to the ignition key. There was a suggestion on here some ago that the wiring and/or connections between sensor and immobiliser may be defective.
Silly question but, not wanting to dismantle unnecessarily, can anyone point me in the direction of the immobiliser in order to check on the condition of the wiring?
Chris
2015 Plus 4 Silverlake Blue (2014 3.7 Roadster Crystal Blue) (2012 4/4 Sport Black)
Posts: 1,246 Likes: 30
Posts: 1,246 Likes: 30 |
I know this has been said. But on my 2011 4/4 I had an intermittent manifestation of the same problem. I then tried using the 2nd key. Well over a year now and so far no reoccurrence. I wonder if some keys are “weaker” than others.
Posts: 102 Likes: 1
Posts: 102 Likes: 1 |
Chris, on my 2018 +4 there is a black box is mounted high up behind the dash which I think is what takes the signal from the loop and decodes it. Has been produced for Morgan by a company called Avonwood Developments Ltd ![[Linked Image]](https://www.tm-img.com/images/2020/08/16/Avonwood.jpg)
Tim Plus 4 2018
