9 members (Joske Vermeule, WAFU_Tom, Steve +8, +8Rich, jbk, mph, Mogdavid, Sir Percival, Alan Patterson),
251
51
Posts837,957
Posts: 425 |
After spending far too long replacing a sidelight bulb in the headlight unit of a GDI I noticed that behind the headlight there were two spare black wires terminating in a small ring terminal. At first sight they appeared to be earth wires for the two bulbs but I could see nothing to connect them to. I didn't check the other unit as I was just about at the end of my tether aligning the tatty rusty little wood screw supplied by the factory. The outcome was that I reassembled the light unit and everything worked as normal. As the hole for the headlight is filled with a what looks like a plastic pudding basin I can see no use for the wires. Have you more knowledgeable chaps any ideas?
John 2015 Plus 4 (GDI) Sport Green
Posts: 8,695 Likes: 415
Posts: 8,695 Likes: 415 |
Likely redundant chassis/ground connections, maybe for wingtop sidelight option. The wiring diagram does show two such black chassis cables within the loom to a single 5mm ring terminal close to o/s headlamp, with one of the black wires routing across to n/s.
