4 members (Player99, Luddite, DaveW, mph), 168 guests, and 41 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,142
#655421 11/08/20 10:10 AM
bilibib Offline OP
The size of the Cotter Pin used with the castellated nut that retains the hub on a 1980's stub axle. It's just I need to adjust the bearings and I don't want to take the pin out and find I haven't got a replacement
Owen
"bilibib"
1982 4/4 Twin Cam, Royal Ivory
1932 Super Sports, Duo tone(two tone)Green
The cotter pin on my stub axle is 1.25” long by 1/8” thick. I believe that’s 31.75 mm by 3.175 mm. They measure from the base of the eyelet to the end of the shorter leg.
Mine is a 1966 Plus 4, but I’m guessing they’re probably the same. Maybe others know if that’s true.
- Nelson
1966 Plus 4 RHD
bilibib Offline OP
Thank you so much Nelson for the information, I have now purchased a packet so there's no excuses for getting my hands greasy now.
Owen
"bilibib"
You're welcome. If you struggle with getting out your old Cotter pins, check out the advice people gave me on my thread on the subject, here: Hub cotter pins
The two most important pieces of advice I can give on that are:
1. The cotter pin does not need to come out in one piece. Don't hesitate to break off the eyelet and remove it in 2 pieces
2. Persistence rules the day.
-N
- Nelson
1966 Plus 4 RHD
