Topics49,908
Posts838,125
Posts: 287 Likes: 8
Posts: 287 Likes: 8 |
The size of the Cotter Pin used with the castellated nut that retains the hub on a 1980's stub axle. It's just I need to adjust the bearings and I don't want to take the pin out and find I haven't got a replacement
Owen "bilibib" 1982 4/4 Twin Cam, Royal Ivory 1932 Super Sports, Duo tone(two tone)Green
Posts: 161 |
The cotter pin on my stub axle is 1.25” long by 1/8” thick. I believe that’s 31.75 mm by 3.175 mm. They measure from the base of the eyelet to the end of the shorter leg.
Mine is a 1966 Plus 4, but I’m guessing they’re probably the same. Maybe others know if that’s true.
- Nelson
1966 Plus 4 RHD
Posts: 287 Likes: 8
Thank you so much Nelson for the information, I have now purchased a packet so there's no excuses for getting my hands greasy now.
Posts: 161 |
You're welcome. If you struggle with getting out your old Cotter pins, check out the advice people gave me on my thread on the subject, here: Hub cotter pinsThe two most important pieces of advice I can give on that are: 1. The cotter pin does not need to come out in one piece. Don't hesitate to break off the eyelet and remove it in 2 pieces 2. Persistence rules the day. -N
- Nelson
1966 Plus 4 RHD
