2 members (Barkingdog, MJF),
216
35
Topics49,844
Posts837,366
Posts: 1,155 Likes: 2
Posts: 1,155 Likes: 2 |
If any one has a four seater with taller screen and 9 stud hood then let’s try ,should be no problem.
Posts: 5,586 Likes: 603
Posts: 5,586 Likes: 603 |
I will most likely be having a set later but, sadly, my resto isn't yet at the point I could do a wiper arc check ..... be nice if it was !  K
Posts: 6,667 Likes: 433
Posts: 6,667 Likes: 433 |
MR11MOG .... I'm guessing, if the interference of the blades with the earlier hood is minimal and not universal, that the blades would likely be fine on an earlier 4 seater with its slightly taller windscreen??
K Work OK on mine (two wiper set up). I'd originally swapped to the better CBS 8" wipers - they worked OK but a large bottom screen overlap at the 'full'' stroke (opposite to park, if that makes sense) These are an inch shorter, and the missing inch is all on one side. Now there is still an overap on the full stroke, but it's much less (under 1 cm). Nowhere near the top of the screen. In fact could get away with an extra half inch of length. I may have a fiddle with the CBS ones and see if I can get an optimum setup.
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
I've just measured the height of the glass part of the screen at the centre line of the Plus 8. Exactly 10 inches: standard "Easy up" hood. I tried to measure the unswept gap between the end of the blade and the top of the glass when at the high point, but even if the ignition is turned off the wipers return to park, they don't just stop. But by eye the unswept bit is about 1".
Posts: 2,086 Likes: 70
Posts: 2,086 Likes: 70 |
K Work OK on mine (two wiper set up). I'd originally swapped to the better CBS 8" wipers - they worked OK but a large bottom screen overlap at the 'full'' stroke (opposite to park, if that makes sense) These are an inch shorter, and the missing inch is all on one side. Now there is still an overap on the full stroke, but it's much less (under 1 cm). Nowhere near the top of the screen. In fact could get away with an extra half inch of length. I may have a fiddle with the CBS ones and see if I can get an optimum setup. That’s about the same as I had and overcame by installing a gear 10 degrees less.
As I'm on a two wiper set up, I wouldn't want to decrease any sweep. Happy to live with the slight overlap.
As I'm on a two wiper set up, I wouldn't want to decrease any sweep. Happy to live with the slight overlap. I first thought likewise but my worry with overlap is that it can tear the end of the rubber over time. Have a close inspection before the MOT as a torn or damaged rubber is a failure.
As I'm on a two wiper set up, I wouldn't want to decrease any sweep. Happy to live with the slight overlap. I first thought likewise but my worry with overlap is that it can tear the end of the rubber over time. Have a close inspection before the MOT as a torn or damaged rubber is a failure. MOT? What's that
As I'm on a two wiper set up, I wouldn't want to decrease any sweep. Happy to live with the slight overlap. I first thought likewise but my worry with overlap is that it can tear the end of the rubber over time. Have a close inspection before the MOT as a torn or damaged rubber is a failure. MOT? What's that  yes, just noticed ‘72.No road tax neither! Lucky you.
As I'm on a two wiper set up, I wouldn't want to decrease any sweep. Happy to live with the slight overlap. I first thought likewise but my worry with overlap is that it can tear the end of the rubber over time. Have a close inspection before the MOT as a torn or damaged rubber is a failure. MOT? What's that  yes, just noticed ‘72.No road tax neither! Lucky you. It does make life easier and cheaper - I do get an unofficial check up at a mates MOT station just to see if I miss anything though
