Originally Posted by John V6
Originally Posted by Arthur S Bell
Not sure whether your 4/4 is the same, Ivormog, but if I am caught out parked in the rain in my 1998 +4, the rain runs in to the heater air intakes through the four bonnet louvres nearest to the windscreen..... As you can see, there are ‘drain’ tubes at the bottom of the heater box (showing the near side in the photo), and I know that some Mog owners have fitted flexible rubber hose pieces to these drains to take any ingressed rainwater down & out of the engine bay.
BTW - I recently bought some matching nylon coated "GORETEX" type fabric and made up an extension for our storm cover, attached across the front section, which completely covers the bonnet louvres...... a couple of 4mm loops of black elastic fasten over the front indicator lamps & all is good now - as long as I remember to put the storm cover on 🤔🤷🏼‍♂️!
Also look inside above the gearbox tunnel there are 2 more drain points. Some are piped through the fire wall. Others just dump on the mats inside.
I've found those 2 drain points now and they have pipes coming into a T piece which then has a single pipe exiting via a tight fitting hole through the passenger footwell so not that.
BTW, note to Simon (SiFab) it's not the washer pipes either although that washer pump sure is powerful.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
