2 members (DaveK, M3WMW), 277 guests, and 30 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,148
Georgetoad, woolfie
#658183 24/08/20 03:31 PM
I would like to give my 4/4 with a 1.8 Duratec a little more grunt at the lower end. Ideally a little quicker throttle response and some better acceleration between 0-50ish, l am aware of a number of options but would welcome advice from some Duratec owners or indeed anyone other Morgan owner.
Chris
2006 4/4 70th Anniversary Edition
2004 3.2 Audi TT Quattro
Chris,
I don't know if the ECU you have with the Duratec is tuneable but if it is, get it on a dyno and have an experienced tuner look at the mapping.
The ECU on my older Zetec was not easily tuneable so I changed it then had a dyno session. It made a significant improvement in the areas you mentioned.
In general, if you change things like exhaust systems there is a tendency to push the power band slightly higher and the ultimate individual throttle body route (ITB) will significantly improve the throttle response but almost certainly improve the top end power at the expense of low end torque.
Increasing low end torque is actually more difficult than increasing higher end power assuming you don't want to turbocharge it or start playing with head modifications, compression ratios and camshafts.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
Hi Chris, I had my 70 anniversary tuned at Williams. It did make a difference but not massively but it did allow you to stay in gear on a hill when before you were changing down so I would say it was worth it. Would also be worth talking to Cain at Wolf.
Ian
2019 +4 110 Anniversary Bentley Velvet Red.
Rog Offline
Here’s one little performance mod for a 1.8 Duratec.
Roger
Thanks for the advice
Roger, do you have a part number for the 2.0 TB?
Chris
Rog Offline
Here you go Chris.
Pic below of a 1.8 on the left and the 2.0 on the right. You should be able to zoom in and see part num and the differences. If you search ebay with “Mk3 Mondeo throttle body” there are always some for sale. I recently purchased a die cast aluminium 2.0L version here.
Just a point regarding your original post. I don’t know if this will give you more grunt at the lower end but might allow a bit more air though at the top end. If you want a tad more grunt then a re-map perhaps might be the answer.
Roger
Thanks everybody, very helpful
Chris
Black Rat
Black Rat
Chris
Cain at Wolf performance does a re-map and it's quick.
Keith
2013 narrow bodied + 4 Ruby.
Chris
Williams Automobiles also have a similar map, if not the same when my IGT intake kit was fitted
Craig Jezz
You could always fit an Omex throttle body kit. People who have done so are very happy with the results evil
