9 members (Hamwich, Dada, britmog, RJW, Rex_tulips, John Winn, Alan Patterson, david nathan, Graham, G4FUJ),
286
36
SORN
New
Topics48,367
Posts813,393
Members9,215
Posts: 14,723 Likes: 149
Posts: 14,723 Likes: 149 |
Just found this on Govt web site:https://www.gov.uk/government/publications/daytime-running-lights/daytime-running-lights
Legislation and requirements:
Vehicle manufacturers must fit DRL to new types of passenger car and light goods vehicle (car derived vans) type approved to European vehicle requirements from February 20111 .
That regulation won't worry me then
Posts: 5,891 Likes: 22
Posts: 5,891 Likes: 22 |
Just run the car all the time with the sidelights on. Save the money.
Posts: 7,910 Likes: 242
Posts: 7,910 Likes: 242 |
Just run the car all the time with the sidelights on. Save the money. Yep simples, it's what the 3.7 Roadsters are wired to do because of the Mustang electrics, just swop the crappy filament bulbs for LED
Posts: 120 Likes: 3
Posts: 120 Likes: 3 |
Just run the car all the time with the sidelights on. Save the money. Also has the advantage of the rear lights being on. Moreover, wingtop Morgan lights are puny attention grabbers compared to modern DLRs, so why not just run with dipped headlights on at all times? Or, if the headlight has an internal sidelight bulb hole, try a Classic Car Daytime Running Lights Conversion Kit from www.bettercarlighting.co.uk/index.php?searchStr=DRL&act=viewCat&Submit=Go Usual disclaimer.
Posts: 6,061 Likes: 160
Posts: 6,061 Likes: 160 |
On mine, I swapped out the old headlights for ones with side lights and wired them into the wing mounted sidelight circuit. Have LEDs in front sidelights and stop/tail lights (also number plate lights/gauge lights). Don't run them all the time (I despise DRLs) but will do if I feel visibility is compromised. As a found out on Thursday evening, they have a minimal drain on the battery ( accidentally left them on for 17 hrs overnight and was still able to start her Ok).
1972 4/4 4 seater, 1981 MGB GT 1984 Harley Davidson Electra Glide, 1990 Kawasaki ZX10
Posts: 26,763 Likes: 425
Posts: 26,763 Likes: 425 |
Well with led sidelight bulbs and headlights with half moon leds in them on permanently on a straight clear road in broad daylight white van t boned me today. Quote I didn't see you and your brakes are really good compared to mine. Frankly I am sure dlrs help but they are out there
Posts: 895 |
Well with led sidelight bulbs and headlights with half moon leds in them on permanently on a straight clear road in broad daylight white van t boned me today. Quote I didn't see you and your brakes are really good compared to mine. Frankly I am sure dlrs help but they are out there Really sorry to hear that John and hope you are OK and hope the damage is easily repaired. At least you had done all you could to be seen. Before fitting LED sidelights I was driving with dipped beam headlights on and had a driver look straight at me and still pull out in front of me. I reasoned he might have thought I was flashing him out so I feel safer with my bright LED sidelights. Sadly though nothing will protect us against people who just don't look.
Rob
4/4 Sport Grey
Posts: 1,180 Likes: 17
Posts: 1,180 Likes: 17 |
DRLs or not. People who just don’t look or are texting. Van man often seen at it. John are the police involved as they may be able to check.
He has owned up so no police. He looked directly at me as well. If I had been on a motorbike I think I would be at best very injured or dead
Posts: 7,944 Likes: 218
Posts: 7,944 Likes: 218 |
Interesting that in the UK DRL's are required to dim with headlights, on full stop. This makes perfect sense in the case of oncoming traffic when you would be using dipped headlamps, but is the dimming necessary on full beam without oncoming traffic? I believe some countries adopt this ruling which makes more sense to me.
Also of interest is the DRL dimming kit that CBS sell (or did). Looking at their wiring diagram the trigger feed is from from headlamp low beam, supporting above thoughts.
